Rear Defrost switch
kenf729
PostPosted: Sat Feb 16, 2008 4:32 pm    Post subject: Rear Defrost switch Reply with quote
Hi guy/gals,
Well Today I finally got around to repalcing my heater core, what a pain that was...also I've noticed that my defrost switch dosn't kick on anymore, wonder if during the 350 carb swap/computer/wiring harnes removal I disconnected something? (worked before) Anyway looking at the plug, looks like this;
x - x = blank spot
With the key on I have power in the middle right wire and left bottom. is this correct? what about the other three?
Edit: Anybody know how to test the switch, or have one?
Thanks guys,
Ken
Edit: my picture of the plug moved...
redlava
PostPosted: Sun Feb 17, 2008 11:21 am    Post subject: Reply with quote
Yeah I have the same problem. The original switch in my car broke and I replaced with one from the junk yard. Which then proceeded to brake again in less that a week. You might be better off using an after market switch.
kenf729
PostPosted: Sun Feb 17, 2008 1:33 pm    Post subject: Reply with quote
do you recall which wires had power to them with the key on? any way to test the switch?
STEEL
PostPosted: Thu Feb 21, 2008 2:10 am    Post subject: Reply with quote
I have a switch from an early z28 dash in the shed. I dont know if it works though. Your welcome to it.
PostPosted: Thu Feb 21, 2008 7:53 am    Post subject: Reply with quote
Weird. Today my defrost switch wouldn't stay engaged.
Stupid switches.
PostPosted: Thu Feb 21, 2008 8:50 am    Post subject: Reply with quote
Yup, the one in my 89 only stays on about a minute, supposed to be like 5 minutes. Found one in the JY, but it does the same thing. Maybe time to buy new?
kenf729
PostPosted: Thu Feb 21, 2008 9:10 am    Post subject: Reply with quote
Love to try it out, would be willing to pay all shipping charges and what ever you want for the switch...
Ken
fulkerl
New Member
PostPosted: Thu Feb 21, 2008 3:34 pm    Post subject: Reply with quote
Ken I think I have that switch... will check and give you a call when I get home....
pathology knight
PostPosted: Sat Feb 23, 2008 11:57 am    Post subject: Reply with quote
mine only stays on for a little while too.
are they on timers?
kenf729
PostPosted: Sun Feb 24, 2008 8:28 am    Post subject: Reply with quote
are they on timers?
From what I understand the switch is a timer. the first time you hit it, it should lsat about 10 mins, then any second hits will be shorter...
pathology knight
PostPosted: Sun Feb 24, 2008 9:19 am    Post subject: Reply with quote
oh, ok.
thanks!
