'92 camaro boss Member
Posted: Tue Feb 19, 2008 6:52 pm Post subject: Transmission question |
ok.. i have an 86 with a 2.8 and a 92 with a 3.1.. are the transmissions the same?.. i want to take the shifter off one and put it on the other, is that possible? and if so, how much work will it be?
and can switch the boots too? without taking the shifter plates?
both are manual, forgot to mention that |
Posted: Tue Feb 19, 2008 8:13 pm Post subject: |
I dont know if shifters changed for the T-5's since I don't run one, but as for your other questions, yes you can swap the boots, and it is fairly easy.
First, pull the shift ball, I like to use a vice-grip and a rag on the stick, to hold it. Then pull the six T-10 screws, and lift it up. There is a frame on the backside that holds the boot on. |
