Posted: Wed Jan 23, 2008 2:23 pm Post subject: Dyno curse got me too. |
Anyone coming down on friday night, happen to have stock brakes and spindles sitting around that you could bring, for me to borrow?
I'll post a picture in a little bit.
--John _________________
Posted: Wed Jan 23, 2008 5:05 pm Post subject: |
| n4pics |
Posted: Wed Jan 23, 2008 5:20 pm Post subject: |
Here you go. From the good old phone camera. You can see how it has shinned the rotor where it contacts the carrier.
Posted: Wed Jan 23, 2008 6:31 pm Post subject: |
| I have one stock spindle I'll have to check which side. Remember we started modifying the other one or we'd have two. If you need John, you can take the calipers off the chevette and run them friday. |
Posted: Wed Jan 23, 2008 6:37 pm Post subject: |
| I would need 2 spindles since mine are already modified. I'm hoping someone **cough** Ian **cough** who has modified brakes, might just have a set of stockers. If not, I'll have to try the scrap yards friday morning. |
Posted: Wed Jan 23, 2008 6:38 pm Post subject: |
| Do you have calipers then if you just need spindles? I'll go up in the attic and check which side I have incase you just have to get one. |
Posted: Wed Jan 23, 2008 6:41 pm Post subject: |
| Dewey316 wrote: | | I would need 2 spindles since mine are already modified. I'm hoping someone **cough** Ian **cough** who has modified brakes, might just have a set of stockers. If not, I'll have to try the scrap yards friday morning. |
I gave one away I can't remember to who, I know it was another crewbie...Oh yeah! John (RSfreak). I've got one side, let me check what side it is...
EDIT: I've got the drivers side. I'm not leaving till evening though. I could pass it on the Al if he were to come through Tacoma? Maybe even give John a call and see if he can stop by with the other one.
They're not my stockers, because I modded my stock ones. They're off a parts car.
I've also got a set of rotors off an s10 I could have turned by then if you want and at least one set of bearings if not two. _________________
Posted: Wed Jan 23, 2008 6:49 pm Post subject: |
Dang! I just sent my stock spindles to Ed but technically I didn't have to. I have the factory calipers sitting in my garage. I would offer up my rotors but they look like they are heat cracked through both of them. Let me know if any of this would be helpful.
How much would the JY charge? You are off Friday right?
Posted: Wed Jan 23, 2008 7:03 pm Post subject: |
| I have no idea what the JY will charge. I do have friday off, now, I just need to hope the car makes it home from work. |
Posted: Wed Jan 23, 2008 8:45 pm Post subject: |
U-pullit is spendy.
Go to boring's U pull U save its like $15 for a spindle |
Posted: Wed Jan 23, 2008 9:04 pm Post subject: |
i don't see the problem...you don't have to use brakes on the dyno
~JAKE |
Posted: Wed Jan 23, 2008 9:05 pm Post subject: |
| 83Z28BlackBetty wrote: | you don't have to use brakes on the dyno
~JAKE |
I have to get TO the dyno. Here, you can put your car in front of my car with no brakes.  |
Posted: Wed Jan 23, 2008 9:06 pm Post subject: |
| Dewey316 wrote: | | 83Z28BlackBetty wrote: | you don't have to use brakes on the dyno
~JAKE |
you could have last year before paint... |
Posted: Wed Jan 23, 2008 9:34 pm Post subject: |
| i dropped off two spindles for john just now. paul and i picked them up a while back for the LS1 conversion i have yet to do. |
Posted: Wed Jan 23, 2008 9:38 pm Post subject: |
Thanks Tony!!! Looks like friday i'll be putting stocker brakes back on, but I should be good for dyno from there.
--John |
fiveoformula Member
i some day wish to live in a world where my buddies get parts for me when i break down  _________________
'88 FORMULA |
Posted: Wed Jan 23, 2008 9:40 pm Post subject: |
| You need to post when you break down. Most of us have a good number of parts laying around. |
Posted: Wed Jan 23, 2008 9:43 pm Post subject: |
Way to go Gambino! Let me know if you want the rotors and/or calipers John.
Posted: Wed Jan 23, 2008 9:45 pm Post subject: |
| I just messaged you, are you not looking at your MSN? |
