Head gasket question
PostPosted: Tue Jan 08, 2008 8:00 pm    Post subject: Head gasket question Reply with quote
So I got the FelPro 1094 shim head gaskets for my car and they are rubber coated, do I still spray them with the Coppercoat? Or just put them on the way they are?
If I do use the Coppercoat, do I spray it on them right before I put the head on, or do I spray it and wait for it to dry?
Also, Paul, you told me which valve cover gaskets to get for these centerbolt valve covers. I forgot, plus you told me about RVT on one side of the gasket and something else on the other side to keep it from sticking. Could you please refresh my memory.
Thanks
PostPosted: Tue Jan 08, 2008 8:08 pm    Post subject: Reply with quote
If the gaskets are coated you don't apply anything. The coating does the job. I use the double thick cork gaskets with the metal center. Napa used to have victor ones which were awesome.. but now they have felpro.. not as nice and $$$ I glue mine to the valve cover and put nothing on the other side. Heard of some people using vaseline on the other side so they wont stick though. Havent had the problem though.
PostPosted: Tue Jan 08, 2008 11:29 pm    Post subject: Reply with quote
USE THE COPPER COAT!
Those are my headgaskets. Everyone on TC and Chevytalk said coat em. 3 gasket sets and no leaks so far! Torqued them down @ 35/45/50/55/60/65
Those last 5lb inciments were recommended on TC and such too to eliminate the need of ever needing to retorque. Don't know if it matters, just what I do now with those gaskets and the coppercoat and no problems for me.
Get everything prepped to install then spray them down. They should look copper. Not copper/black. You'll get the hang of it. Follow the directions. I think you let it setup for a few min then put it on. It's kind of a indefinitely tacky thing. Cleans super easy with brake clean.
Like B said on the valve cover gaskets. Double cork, metal center. Glue (Gaskecinch) one side to the valve cover. Set it on the work bench, put some weight on it and let it setup. Then a nice thick layer of vaseline on the other side, then pop the badboy on the head.
Very Happy
PostPosted: Wed Jan 09, 2008 7:08 am    Post subject: Reply with quote
Alright, thanks guys.
Time to get to work on it.
pathology knight
PostPosted: Wed Jan 09, 2008 7:28 am    Post subject: Reply with quote
not sure if this applies... (in regards to the valve cover gaskets)
but be cautions with those felpro gaskets. i got a set for my 89 t/a (they were orange) and they didn't really fit. i paid a little extra for them, being i thought they would be better, and they weren't....they were to short! i had everything at my family's garage (middle of nowhere) so i didn't have time to take them back. i got them to work (jimmy rigged) but i wouldn't buy them again.
i'm sure i just got a fluke set, but i thought i'd share.
PostPosted: Wed Jan 09, 2008 7:34 am    Post subject: Reply with quote
Too short? How so.
We are using these gaskets on Tall, ball milled aftermarket valve covers. Not on stock covers.
pathology knight
PostPosted: Thu Jan 10, 2008 9:11 am    Post subject: Reply with quote
the valve covers fit just fine. (aftermarket)
the gasket underneath was to short.
PostPosted: Thu Jan 10, 2008 9:23 am    Post subject: Reply with quote
The rubber ones are designed to be a stretch fit.
PostPosted: Thu Jan 10, 2008 9:25 am    Post subject: Reply with quote
hehehehe,,,,rubber,,,,,,,sssstttttrrreeeeettccccchhhhhhhhh,, Laughing
PostPosted: Thu Jan 10, 2008 9:27 am    Post subject: Reply with quote
FWIW, I have the rubber coated shim gaskets on my car, I didn't copper coat, and I can't say that I have noticed my head gaskets leaking....
And I have always used the rubber stretchy centerbolt gaskets when I had them.
--John
PostPosted: Thu Jan 10, 2008 9:41 am    Post subject: Reply with quote
I used the rubber centerbolts as well. I actually glued them to the cover with that weather seal stuff and then bolted them down. Must have worked good cause they're still on there. Very Happy
pathology knight
PostPosted: Thu Jan 10, 2008 2:14 pm    Post subject: Reply with quote
i think i had to use some glue too.
they would stretch, but i had to stretch them so far they would stay in place! Embarassed
live and learn.
PostPosted: Thu Jan 10, 2008 5:37 pm    Post subject: Reply with quote
The rubber ones work dandy on stock type valve covers. When you get the ball milled aluminum covers though there's no inner lip to hold the gasket in place. With these you have to go to a cork gasket, preferably one with the steel insert. I think you'd have to use super glue to get a rubber one to stick to the ball milled covers.
PostPosted: Thu Jan 10, 2008 5:56 pm    Post subject: Reply with quote
How think are those 1094's?
PostPosted: Thu Jan 10, 2008 6:01 pm    Post subject: Reply with quote
Dan, I think they are .015"
--John
PostPosted: Thu Jan 10, 2008 6:28 pm    Post subject: Reply with quote
Thanks John. I'm shooting for a .040 quench, so hopefully I'll have the piston down .025 in the bore, a .015 gasket should be perfect. But will have to get the pistons in the bore and see for sure where they are.
PostPosted: Thu Jan 10, 2008 10:04 pm    Post subject: Reply with quote
Yup, I ended up using a set of the rubber gaskets, seems none of our wonderful autoparts stores had the cork with the steel insert. I'm not paying Summits shipping fee for one little item. I glued them into the covers and used some little clamps to hold the gasket in place.
PostPosted: Thu Jan 10, 2008 10:12 pm    Post subject: Reply with quote
The trouble I had wasn't that they slid out into the valve train area, but that they weren't thick enough. The valve cover would bottom out before sealing. This might be a protopline problem. IIRC the valve cover would hit the perimmeter(sp?) bolt flanges before the gasket sealed.
PostPosted: Thu Jan 10, 2008 10:15 pm    Post subject: Reply with quote
HATED the rubber valve cover gaskets. Have been using the cork/steel valve cover gaskets for about 4 years (same set) with no issues.
Felpro head gaskets with no copper coat with no issues. But I don't have an engine that pushes the envelope much.
PostPosted: Fri Jan 11, 2008 7:17 am    Post subject: Reply with quote
Your felpro headgaskets are the composite ones that squish alot. We're talking about the steel shims that don't have alot of squish to them.
I'm getting my engine decked when it comes out next. Then I can use the .040 gasket too.
