Ostrich
Raiden
PostPosted: Fri Jan 04, 2008 7:00 pm    Post subject: Ostrich Reply with quote
Ostrich, is it worth the extra cash or not? Confused Does it make prom tuning much easier or do you really need a wide band with it to really work? Confused
PostPosted: Fri Jan 04, 2008 8:10 pm    Post subject: Reply with quote
I can't speek to the Ostrich as I have no experience there. I would say that you want a wide-band 02 sensor to aid in your tuning regardless of EFI system or carb. It will provide you with exactly what the air/fuel ratio is not whether you are higher or lower than stoich.
