Posted: Sun Dec 16, 2007 10:34 am Post subject: Fuel gauge sending unit |
I've dealt with a non working fuel gauge for over a year now and finally I'm sick of it. I've tested the gauge itself by taking out the sending unit from the tank and grounding it out and sure enough the gauge went down to empty (always reads past full.) So all wiring and the gauge are in working order, just not the sending unit.
I'm need the whole sending unit assembly, I just replaced my fuel pump last winter so I'll just swap that over. My car is an '85 with an LB9 (not sure if sending unit's differ.)
So if anyone has an extra one just lying around or one from a parts car or something let me know, I'm on a super tight budget here but I still want the gauge to work. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
