TBI Open Element install problem
Red Bird
1991 Pontiac Firebird
PostPosted: Tue Nov 06, 2007 8:04 pm    Post subject: TBI Open Element install problem Reply with quote
So i picked up a 13"x4 open element air cleaner and a 1" spacer to clear the coil by the distributor. It fits but the stud coming out of the TBI unit is too short to get the wing nut on. Has anyone run into this? I left the gold ring around the throttle body on, should it be removed? do i need a certain type of drop base aircleaner? or do i have to remove the stud and replace it with a longer one? if so do i have to take the Throttle body off? i tried spinning it out, but the edge hits the injectors on each side. any suggestions would be most appreciated.
1991 Firebird L03 T-5
PostPosted: Tue Nov 06, 2007 8:31 pm    Post subject: Reply with quote
Can you fit it without the gold spacer? If so, just do that. I use a drop base on mine. You can take the stud out, but unplugging the injecotrs, once the electrical connector is out the way, you should have room to undo the stud.
--John
PostPosted: Wed Nov 07, 2007 11:22 am    Post subject: Reply with quote
i unscrewed my stud about half way so i could the wing nut on, mine was just barely to short...
'88 FORMULA
