85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Wed Sep 19, 2007 1:09 pm Post subject: |
| Single fan, probably controlled in the computer only. |
Actually, I know it was controlled by the computer because I had one.
When I got a hypertech chip, the fan on temp changed. So yeah.
That's what's up.  |
Posted: Wed Sep 19, 2007 9:49 pm Post subject: |
Just install a manual fan switch. fairly easy and much cheaper. I've got one on my 85 LB9. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
85 T/A WS6 Member
Posted: Thu Sep 20, 2007 10:01 am Post subject: |
It's of personal experiance and documentation.... that you cannot properly create a chip without having the car present to do so.
You can get a calibration that gets the car to run and function, but not at an efficient level. |
