Fuel Filter...
Brizio
1985 Chevrolet Camaro IROC-Z
PostPosted: Wed Aug 29, 2007 2:44 pm    Post subject: Fuel Filter... Reply with quote
Hello!
Where is the fuel filter on a 305 IROC??? I need clear or change it because the car don't run very well...
PostPosted: Wed Aug 29, 2007 2:50 pm    Post subject: Reply with quote
It is under the car, right in front of the rear/drivers side wheel. You will need a 3/4" and a 5/8" open ended wrench, or flair-nut. YOu also need a 10mm socket to under the bracket.
--John
(I just did mine on Sunday)
PostPosted: Wed Aug 29, 2007 2:54 pm    Post subject: Reply with quote
You will also want to loosen the gas cap if you have a pressurized system. You'll still get fuel leaking on you, but it will minimize the spray.
Brizio
PostPosted: Wed Aug 29, 2007 3:13 pm    Post subject: Reply with quote
Thanks! Now I go to search it! Surprised
