Fog light replacement 91-92 Firebird
Red Bird
1991 Pontiac Firebird
PostPosted: Tue Aug 28, 2007 6:33 pm    Post subject: Fog light replacement 91-92 Firebird Reply with quote
Hey, i just noticed that the left fog light in my birds bumper went out. Does the whole light need to be replaced? or is there a bulb i can put into the old housing. I havent gotten around to taking a good look at it yet, but i figured there may be somemone on here thats had to replace them.
1991 Firebird L03 T-5
PostPosted: Tue Aug 28, 2007 7:07 pm    Post subject: Reply with quote
It's a standard h3 bulb that installs from the backside. Although, it's a chore getting out. You'll have to unscrew the turn signal to get to both screws of the foglight. I think they're a t15 screwhead.
Red Bird
PostPosted: Tue Aug 28, 2007 8:12 pm    Post subject: Reply with quote
I see, thx for the reply, i'll have to swap it out when i get the chance
J-Dog-III
PostPosted: Wed Aug 29, 2007 9:02 pm    Post subject: Reply with quote
No means of highjacking but will those bulbs work in stock fog lights for a 87 iroc? both mine are out and i need to replace them
PostPosted: Thu Aug 30, 2007 7:07 am    Post subject: Reply with quote
The bulb itself should be the same, but I have no idea on how to gain access to them. I'm pretty sure GM used the same foglight bulb until the mid 90's.
PostPosted: Thu Aug 30, 2007 8:52 am    Post subject: Reply with quote
Fog lights on an IROC are a lot easier than on the Birds. On either side of the glass there will be two screws, either T-10, or phillips, can't remember. Once you get the glass off, just yank the bulb.
BTW, Ian, do you know if Schucks still sells those "Blazer Industries" foglights? My dad has a set on his truck, and they're almost identical to the stockers on my IROC.
