Steering column for 89…
kenf729
PostPosted: Mon Aug 20, 2007 8:02 am    Post subject: Steering column for 89… Reply with quote
Hello everone, Anyone have a good steering column laying around or a good wiper switch that I could swap out? My wiper switch is shot, also previous owner ran a wire from the switch directly to the starter by passing VATS, I think the PO screwed up since I have a steady draw on my battery. I now have the computer out so I thought I'd re-do his work...I'm thinking a complete column swap would be the easy route to go...
Thanks.
Ken
PostPosted: Mon Aug 20, 2007 9:40 am    Post subject: Reply with quote
the wiper switch is easy to get too in the column once the column is out.. so if you can't find a column thats always an option... i could even help.. having done it a few times now. Smile
kenf729
PostPosted: Mon Aug 20, 2007 10:18 am    Post subject: Reply with quote
thanks appreciated the offer...I thought I'd read that there is a special tool for getting down to that level??? The Steering wheel should be easy to pull, but thought there were some pins or bolts or someting that required a special tool...
Was looking at the wiper switch yesterday...I know this isn't supposed to happen but the whole arm can be pulled right out...something within the housing must be broke?
TecherB
Princess B
PostPosted: Mon Aug 20, 2007 3:45 pm    Post subject: Reply with quote
i have a steering column laying around if you want it you can have it durt cheap. cant remember what year it is from. the colimn is complete steering wheel and keys as i remember.
just pm me if you are intersted
PostPosted: Mon Aug 20, 2007 11:31 pm    Post subject: Reply with quote
you will need a lock ring depressor, and if you have an airbag a set of c-clip pliers. both of which i have, and will lend to a crewbie in need.
also, i have a spare column parts as well.. and if the one you buy off bart is not equiped just right we can kitbash your two columns together and make one good one from the two bad ones and my spare parts.
Smile
kenf729
PostPosted: Tue Aug 21, 2007 7:24 am    Post subject: Reply with quote
Tony, thanks for offerring, I may need to take you up on the lock ring depressor, Bart's steering column is complete except for the wheel...which I have...sounds like it may be a complete bolt in setup...
Ken
PostPosted: Sun Aug 26, 2007 10:58 pm    Post subject: Reply with quote
cool, just let me know if you need it. i check my PMs daily.
