Honing cylinder
kurfbird
PostPosted: Wed Aug 22, 2007 9:27 am    Post subject: Honing cylinder Reply with quote
I have a few questions
Okay #1 cylnder had low compression 75 PSI. I checked the valves and they look good when I removed the head. Dont seem to be burnt nothing missing.
I purchased a set of stock rings. From reading Looks like a ball hone would be the best to hone the cylinder and then installed the new rings.
I have never hones a cylinder before. Can you take me through the steps.
How do you measure the ring gap on the cylinder.
Is there anything else I need to do on this evelution.
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Wed Aug 22, 2007 11:24 am    Post subject: Reply with quote
A ball hone is really best for a used cylinder. The ball type hone conforms to the cylinder taper, and a hone with stones on it doesn't really work as well on a used (worn) cylinder. But on a fresh bore I'd only used a stone type hone, and I'd only let a professional do this with a Sunnen machine.
To measure rig gaps, push the ring into the cylinder past the top 1/2" or so, make sure it's square on the bore (a piston to push it down works great) and use feeler gages to measure the end gap.
kurfbird
PostPosted: Wed Aug 22, 2007 7:41 pm    Post subject: Made some decisions Reply with quote
Pulling the motor out of the car.
Going back to my orginal motor
Taking low compresson head to the machine shop and have them do a valve job and see if the valves were my problem.
If its the valve were the problem I wont hone.
A few people on TGO dought that the compresson would drop to 75 psi and all the rest were good between 135-150 PSI
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
