Why can't we just live W/o California?
PostPosted: Thu Aug 09, 2007 8:53 am    Post subject: Why can't we just live W/o California? Reply with quote
Two cats and I failed this time. Even dropped the timing down 4º and set the AFR to 15.0
It seems as though the "miss" problem at steady state cruise is screwing me.
I put new plugs on at cows.
Followed by new wires afterward.
Still, mostly dominant in lower gears, you can feel a jerkyness miss. Felt more than heard. In higher gears you don't seem to feel it as much but the vacuum is lower there too.
IIRC last year I had a similar problem and it turned out to be distributor cap/rotor. Only gave a miss at light cruise.
Guess I'll give that a try and lean out the cruise spot some more.
On a positive note, I have the emissions of a geo at idle!
HC Cruise = 185
Limit = 150
HC Idle = 52
Limit = 220
CO Cruise = .62
Limit = 1
CO Idle = .01
Limit = 1.2
And my fuel pump came, but I can't very well do anything with it eh.
PostPosted: Thu Aug 09, 2007 8:58 am    Post subject: Reply with quote
I have a cat in my garage, maybe 3 is the magic number. Wink
PostPosted: Thu Aug 09, 2007 9:00 am    Post subject: Reply with quote
That may be! I'd still like to eliminate this miss though!
PostPosted: Thu Aug 09, 2007 9:09 am    Post subject: Reply with quote
BTW, are you working saturday? I'm moving and an extra body would be helpful. I'll suply beer (or lemonade) and pizza.
--John
PostPosted: Thu Aug 09, 2007 11:10 am    Post subject: Reply with quote
John, I'm houssitting for the G/F's family this weekend. I might be able to pitch in a hand for a few hours Saturday. You're only about a mile from where I'll be at.
PostPosted: Thu Aug 09, 2007 11:13 am    Post subject: Reply with quote
cool, the more help, the faster it goes. I'm just moving from the place you know, down to 227th and Halsey, so it isn't too far.
--John
PostPosted: Thu Aug 09, 2007 11:23 am    Post subject: Reply with quote
cool. What time is this getting started at on Saturday?
PostPosted: Thu Aug 09, 2007 11:44 am    Post subject: Reply with quote
haha, I don't know. The scrap yard is coming to pick up the junk car, I need to pick up the uhaul, I have to sign papers on the new place. Want me to just call you when I have an idea?
--John
Brizio
1985 Chevrolet Camaro IROC-Z
PostPosted: Thu Aug 09, 2007 1:05 pm    Post subject: Reply with quote
I have the same problem... For the second time the Camaro fail the test... Ok the first time was without cat. : ) But the second she had one new!
The result of the second time...
HC STD CO STD HC CO CO2
Idle 220 1 288 2.2361 12.9
2nd Idle 220 1 320 1.5203 13.4
And also smoke little bit... : (
Now I don't know what make on it...
redlava
PostPosted: Thu Aug 09, 2007 3:10 pm    Post subject: Reply with quote
just an idea maybe if you can use some ones old 2.73 rear just for the test so your cruise is at a lower rpm.
PostPosted: Thu Aug 09, 2007 4:16 pm    Post subject: Reply with quote
--John
Sounds good dude. I'll PM you the number to the house were at later.....junking the donor car eh? Man. Some fun with a plasma cutter could be had... Twisted Evil
PostPosted: Thu Aug 09, 2007 4:54 pm    Post subject: Reply with quote
Or we could have paul try to park the jeep on top of it. Very Happy
PostPosted: Fri Aug 10, 2007 9:09 am    Post subject: Reply with quote
hehehe
John I'm working until 3(could squeek out at 230.)
I can give you a call when I get off.
EDIT: Just remembered I have some goofy house warming thing to go to with brandy and my parents tomorrow evening. I'll let you know if we don't end up going or something! Sorry!
I'd be glad to help. I can pick up that cat too. Probably gonna need it. 185 over 150 isn't that far off. Maybe if i figured out what cyl is missing I can just unplug that injector lol.
As for the lower geared rear.... that might cause adverse effects. As it stands the cruise part was conducted in 3rd gear at 25mph. That was 1650RPM. In all reality I'd prefer it to be a higher rpm due to the cam.
PostPosted: Fri Aug 10, 2007 1:05 pm    Post subject: Reply with quote
so ride the clutch Very Happy
paul, i also have another cat if you want to borrow it.
