Posted: Wed Aug 01, 2007 6:13 pm Post subject: FREE. shifter. 3rd gen and 4th gen factory shifters |
i have factory shifters from third and fourth generation cars as well as factory ebrake leaver and handle from a 4th generation car.
free, but must pick up before the tenth. |
Demon 12sec Club
Posted: Wed Aug 01, 2007 6:38 pm Post subject: |
| factory shifter or factory hurst shifter for the 4thgen? |
Posted: Wed Aug 01, 2007 7:37 pm Post subject: |
auto shifter  |
Posted: Thu Aug 02, 2007 12:50 am Post subject: |
I'll take 'em. My shifter is broken internally and my E-brake handle has seen better days. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Thu Aug 02, 2007 7:20 am Post subject: |
| Demon wrote: | | factory shifter or factory hurst shifter for the 4thgen? |
If you need the stock non-Hurst style, I have one sitting in the garage. The rubber covor and the knob are worn out, but it works fine. |
Posted: Thu Aug 02, 2007 8:00 am Post subject: |
| double take, when do you want to pick them up? i should be around later in the day on friday as well as today after six. |
Posted: Fri Aug 03, 2007 12:53 pm Post subject: |
You've got PM. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
