What can break in a pressure regulator?
PostPosted: Fri Jul 20, 2007 12:18 pm    Post subject: What can break in a pressure regulator? Reply with quote
Previous owner had an AFPR installed on my TPI. I took it apart today, cleaned everything up, and checked it out. The spring and diaphragm and everything looked to be in good shape. The only problems I've ever heard of were based on a blowout in the diaphragm itself. Is there any other potential trouble spots I should check before I put this all back together?
