Jake's suspension upgrade thread!!
PostPosted: Tue Jul 17, 2007 9:54 pm    Post subject: Jake's suspension upgrade thread!! Reply with quote
So I got the first few parts in the mail today!!
KYB Gas-adjust rear shocks
KYB GR2 gas front struts
New universal joints
Saturday I'm planning a trip to Tacoma to pick up a set of WS6 springs and new tie-rod ends from Ian.
Sunday is the big day of fun and installation!
PostPosted: Wed Jul 18, 2007 9:05 am    Post subject: Reply with quote
Very Niace! I think those are the same shocks I have in the V6 car. Beef Cake. Your ride will handle awesome with the setup path you're going. Any plans for urethane? I have some diy suspension upgrades you could do.
PostPosted: Wed Jul 18, 2007 9:49 am    Post subject: Reply with quote
That should work very nice. Similar to my setup (I have Tokico Illumina adjustables), I love the WS6 springs I have. You may want to get some spring isolators for the tops of your springs, my front ones were shot (they're cheap too, maybe $10 pair). What size sway bars do you have? Are you going to upgrade those too? Mine seems to be pretty flat around the exit/entrance ramps at 60+ mph with the 34/24 mm combo.
PostPosted: Wed Jul 18, 2007 9:52 am    Post subject: Reply with quote
Thats the same sway bar setup I run on my LT1. Seems to be a pretty solid setup and I recommend it for V8 cars. I also recommend urethane bushings for the panhard bar. Made the rear feel connected. I didn't notice how loose it was until I made the change.
PostPosted: Wed Jul 18, 2007 8:59 pm    Post subject: Reply with quote
Jake, you need sways too?
PostPosted: Wed Jul 18, 2007 9:23 pm    Post subject: Reply with quote
umm... I think i have 32/22mm combo. I'd like to step it up to the 34/24mm
whatcha got in mind??
where did you get them?
Haven't thought about urethane yet Embarassed that will have to come a few paychecks later
Last edited by 83Z28BlackBetty on Wed Jul 18, 2007 9:41 pm; edited 1 time in total
PostPosted: Wed Jul 18, 2007 9:40 pm    Post subject: Reply with quote
I think I've still got at least the 36mm front bar from my 87.
PostPosted: Wed Jul 18, 2007 9:42 pm    Post subject: Reply with quote
*drools* I'd be interested for sure!
PostPosted: Thu Jul 19, 2007 7:32 am    Post subject: Reply with quote
Urethane is cheap. I think its around 20 bucks to do each part. You can also get urethane endlinks for the sway bars from the parts store. Those are $8 a side. Cheap.
PostPosted: Thu Jul 19, 2007 6:14 pm    Post subject: Reply with quote
Energy Suspension Thumbs up
The rear sway bar kit comes with everything, including end links, the front has only the poly bushings, end links are separate. Use your old front brackets unless you get greaseable bushings, then the brackets should come with.
PostPosted: Sun Jul 22, 2007 8:04 pm    Post subject: Reply with quote
OOOOMMMMGGG!!!! Very Happy Very Happy Very Happy Very Happy Very Happy
My car is sooooooo amazing!!!
Big thanks to Ian for discounted parts and some freebies. I owe you one bigtime. Thumbs up
So today I put in the new shocks, struts, a set of ws6 springs, 36mm front, 24mm rear sways, and new inner and outer tierod ends. :phew: *wipes sweat, blood, and tears off head*
All i have to say is that i feel like i'm driving the fastest, coolest, and best handling car on the road right now.
SUCCESS!!
~JAKE Very Happy
PostPosted: Sun Jul 22, 2007 8:11 pm    Post subject: Reply with quote
Awesome Thumbs up
Pretty flat in the corners now, huh?? Now to get SFC's, I put in an order for them yesterday - UMI is doing a group purchase now for 15% off through TGO and still needs some orders to fill.
PostPosted: Sun Jul 22, 2007 8:19 pm    Post subject: Reply with quote
You're welcome man!
Glad I could help. I knew I could've charged you out the arse for all that crap but that's not the spirit of the crew! I'm glad everything got worked out. The other store had all the tie rods?
Handling and steering is a lot more solid now, eh? Very Happy
PostPosted: Sun Jul 22, 2007 8:23 pm    Post subject: Reply with quote
Excellent Thumbs up Glad you are having fun. Poly bushings and endlinks was one of the first things I did to my car. Fairly cheap and noticeable difference.
Good on ya Ian Cool
PostPosted: Sun Jul 22, 2007 9:16 pm    Post subject: Reply with quote
yeah, my car turns when i turn the steering wheel! novel concept isn't it. Razz
yeah ian, other store had em, but one of them had a big bend in it so i had to go to a different store. but it all worked out. and i have to say that the generosity and true caring about each other is what i think is so great about this group of guys Smile
There is an transfer-ramp between 2 freeways that i would take at about 45-50 before because i would bottom out when going over the metal ribs. BUT...today i took it at 80mph and it wasn't wavering one little bit!
so solid
