I don't think this is enough belt contact.
PostPosted: Wed Jun 13, 2007 7:24 pm    Post subject: I don't think this is enough belt contact. Reply with quote
Got the alternator bracket on. Now I need to decide what to do with then PS pump. Shave the bracket down or buy/make a new one so I can sell the complete serp setup.
And holy crap does it open up the engine bay. The motor looks a lot taller now that I can see the heads.
PostPosted: Wed Jun 13, 2007 7:28 pm    Post subject: Reply with quote
Might work, but i'd like more wrap around that myself. I dont think the water pump actually has a whole lot of drag on it though. Is the pulley a smooth or grooved pulley? And which direction water pump do you have on it? If its the stock rotation pump for your year that will be turning it backwards.
PostPosted: Wed Jun 13, 2007 7:57 pm    Post subject: Reply with quote
What bracket is that?
I need to move my alternator down like that to make room for a couple of M90 superchargers....
PostPosted: Wed Jun 13, 2007 8:13 pm    Post subject: Reply with quote
The water pump I swapped from an earlier style so it rotates the correct way. It only squeals at 5k. So...instead of a shift light, it's a shift squeal. Laughing
My stock water pump didn't have a bolt hole for the turnbuckle down below.
PostPosted: Wed Jun 13, 2007 9:25 pm    Post subject: Reply with quote
i have been looking to do the same thing for a while. but i don't like the idea of having so little belt contact on the water pump.
PostPosted: Wed Jun 13, 2007 11:05 pm    Post subject: Reply with quote
I think you'll be fine.
if you see the lights dim or some squeeky squeeky might try something else lol.
PostPosted: Thu Jun 14, 2007 11:04 am    Post subject: Reply with quote
would the Vbelt power steering pump bracket work?
PostPosted: Thu Jun 14, 2007 4:10 pm    Post subject: Reply with quote
No way... no how... no good. That's not even close to enough belt wrap! And the fact that it is your water pump makes this a disaster waiting to happen. Get a different belt routing.
PostPosted: Thu Jun 14, 2007 4:50 pm    Post subject: Reply with quote
I would almost think going back to the counter rotating pump and the smooth pulley would be better. then wrap the backside of the belt around it somehow. May need an upper idler somewhere.. hard to tell with just a pic.
PostPosted: Thu Jun 14, 2007 6:48 pm    Post subject: Reply with quote
Took a look at it today. Going under the pump looks like it might reduce contact even more, and an idler pulley would be hard, although probably not impossible to mount.
I think Ian is right, redoing the PS pump bracket would probably do the trick. Either lower, or with a smaller pulley.
PostPosted: Thu Jun 14, 2007 10:50 pm    Post subject: Reply with quote
yeah, what bracket is that?
Sellmanb
PostPosted: Fri Jun 15, 2007 6:05 am    Post subject: Reply with quote
you can always try different belt routings/belts.
