Posted: Sun Jun 10, 2007 9:26 pm Post subject: Couple of hours on the park lights |
I spent a couple of hours on the park lights of the 89 today. Removed the housings, cleaned the lenses, rinsed out the insides. Before I put them back in, I cut a notch in the bumper to line up with the vent hole in the light. Now the vent isn't blocked off any more to collect the moisture and dirt. They're not perfect, but look much better and will do until either I replace them or upgrade my headlights and use the clear ones I have lying around
What they looked like when I bought the car last August...
After a couple of hours today....
 _________________ 92 Camaro
Posted: Sun Jun 10, 2007 9:50 pm Post subject: |
| I'm gonna need to do that myself pretty soon. Any special cleaners to use on them, or just water and a rag? |
Posted: Sun Jun 10, 2007 10:00 pm Post subject: |
I used Meguiar's Clear Plastic Polish and Clear Plastic Cleaner for the outside. Could have done some wet sanding too, there are some pits in the lenses yet, but it looks so much better than before. _________________ 92 Camaro
Posted: Sun Jun 10, 2007 10:14 pm Post subject: |
| How'd you get the inside so darn clean? Mine look super nasty like that |
Posted: Sun Jun 10, 2007 10:17 pm Post subject: |
Actually, they're not that clean on the inside. All I could do was to rinse them out with high pressure water from the garden hose and shake them out. There are still small bits of stuff in them between the diffuser and the lens. _________________ 92 Camaro
BigDaddyVu 12sec Club
Posted: Mon Jun 11, 2007 12:17 am Post subject: |
| you can use compressed air and a shop vac |
Posted: Mon Jun 11, 2007 12:22 am Post subject: |
Wasn't there a slight explosion involved with that BigDaddy?  |
Posted: Mon Jun 11, 2007 10:08 am Post subject: |
| How did you get the front lense off? I've done this before but I had to cut it. |
Posted: Mon Jun 11, 2007 10:14 am Post subject: |
| Twilightoptics wrote: | | How'd you get the inside so darn clean? Mine look super nasty like that |
| Al Hasse wrote: | | Actually, they're not that clean on the inside. All I could do was to rinse them out with high pressure water from the garden hose and shake them out. There are still small bits of stuff in them between the diffuser and the lens. |
| blue89 wrote: | | How did you get the front lense off? I've done this before but I had to cut it. |
Never took the assembly apart, just used th hose to clean the inside as best I could  _________________ 92 Camaro
Posted: Mon Jun 11, 2007 12:09 pm Post subject: |
I made some clears from my stock ones. The front lense does not come off easy.. in fact, I dont recommend taking the front lense off.
Guess I need to post pics of mine now that I opened the can o worms huh?
gonna have to be later tonight. |
Posted: Mon Jun 11, 2007 12:58 pm Post subject: |
| if it blows up you don't have to worry about it anymore |
Posted: Mon Jun 11, 2007 12:59 pm Post subject: |
| just try not to end up in the E.R. |
Posted: Mon Jun 11, 2007 6:55 pm Post subject: |
| BigDaddyVu wrote: | | if it blows up you don't have to worry about it anymore |
Now that's the attitude to have!  |
Posted: Tue Jun 12, 2007 4:00 pm Post subject: |
Heres mine. Yes, these are factory gm lights.
[/img] |
Posted: Tue Jun 12, 2007 4:49 pm Post subject: |
| Quote: | | What they looked like when I bought the car last August... |
Man I wish mine would look even like that. Mine are horrible. I've tried cleaning, toothpaste, and wet sanding and you still can barely see through the front lens. I''l pick up some plastic polish and see what that'll do. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Jun 12, 2007 8:50 pm Post subject: |
| I didn't know you did the clear mod!?!?! |
Posted: Tue Jun 12, 2007 8:53 pm Post subject: |
| I like that, I may have to do it at some point. Or maybe I'll get the diamond cut ones like Al had at one point. First is the HID stuff. Freakin true bi-xenon projectors are bloody expensive. |
Posted: Wed Jun 13, 2007 4:00 am Post subject: |
| blue89 wrote: | | I didn't know you did the clear mod!?!?! |
I sent a txt msg to your phone with a pic attached after I did them. you must not have gotten it.
I had a weekend to burn, so I did this. Its a real PITA, I would recommend paying the 60 for the real clears. |
