Flywheel and Exhaust
PostPosted: Wed May 30, 2007 9:06 pm    Post subject: Flywheel and Exhaust Reply with quote
I could use a flywheel for my L69 project car. Just a standard 153-tooth for a T-5.
Also, I need to get myself exhaust, preferably headers, and a matching Y-pipe.
Together, these will provide the last two pieces to complete the puzzle and get my car on the road! Burnout
It would be awesome if we could pull off an on-the-way-to-or-from-Cows handoff! Here's hoping I get my heads by the end of the week!
(P.S. - It sucks to be just learning Dvorak! Evil or Very Mad )
PostPosted: Wed May 30, 2007 9:38 pm    Post subject: Reply with quote
1 Piece rear or 2 Piece rear for the flywheel?
PostPosted: Thu May 31, 2007 5:31 am    Post subject: Reply with quote
Thanks for reminding me. 2 piece.
PostPosted: Thu May 31, 2007 7:15 am    Post subject: Reply with quote
You can pick up a brand new 153 2 piece hayes flywheel from summit for about $150. The 1 piece flys are more expensive and harder to find used.
Just a heads up.
PostPosted: Thu May 31, 2007 4:08 pm    Post subject: Reply with quote
The cheapest flywheel I can find on Summit for my application is a GMPP $190 one. I really wouldn't like to spend that much money on a flywheel. Hence my search for a used one!
PostPosted: Thu May 31, 2007 9:58 pm    Post subject: Reply with quote
Is that the 10.5" one? I think I've got one sitting in the garage. Lemme check It's got the larger bolt circle?
PostPosted: Fri Jun 01, 2007 6:28 am    Post subject: Reply with quote
Yeah, 10.5 inch.
I've never actually had one in my possession, so I'm not sure about the larger bolt circle bit. Maybe Paul knows?
PostPosted: Mon Jun 04, 2007 12:08 pm    Post subject: Reply with quote
2 piece rear- pre '87 large hole fly
1 piece rear - '87 + small hole fly
