Posted: Tue Apr 24, 2007 9:51 pm Post subject: Pair of Tires ASAP |
My tire developed a blister and now the steel mesh is showing through, rendering my car unsafe to drive at the moment. I need a pair of tires for the rear. I have 16x7 wheels and currently have 245/50ZR16's wrapped on all four corners. However, I wouldn't mind having a staggered set up. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
Posted: Tue Apr 24, 2007 10:48 pm Post subject: |
| if you just need something short term I've got two screwed up 16" tires on formula wheels sitting on my porch. they were run on a car with bad alignment and are almost bald on the insides. they would probably serve you for about 2000 miles before they looked like the one you have now. i WAS going to burn 'em off at cows but if you NEED some tires i could part with them for a small fee. |
Posted: Sun Apr 29, 2007 2:29 am Post subject: |
Well it looks like I may have to take you up on that offer. PM sent. _________________ Richmond 3.73 posi| 36/24 sway bars | SLP LM2 | Koni's | Ground Control 800/200 | Y2K wheels | Dyno Don headers & Y-pipe | airfoil | BBK underdrive pulleys | Raised strut mounts | Extended ball joints | LCARB'S
