t-56 ?
Goto page 1, 2, 3  Next
PostPosted: Wed Apr 18, 2007 6:30 pm    Post subject: t-56 ? Reply with quote
who in here has installed a t-56 in there 3rd gen
PostPosted: Wed Apr 18, 2007 6:45 pm    Post subject: Reply with quote
Talk to Ian...
PostPosted: Wed Apr 18, 2007 6:48 pm    Post subject: Reply with quote
Also Twilightoptics. I'm sure there might be more. I'm wanting to do that with my 89 in the near (?) future.
PostPosted: Wed Apr 18, 2007 7:06 pm    Post subject: Reply with quote
the t-56 is out of a 97 ss camaro. drive line, cross member, and bellhousing is what came with it. what parts do i need to mate it to the engine
PostPosted: Wed Apr 18, 2007 7:16 pm    Post subject: Reply with quote
Since I've been toying with the idea, I've done a little research on the internet and came across this article among others http://sethirdgen.org/t56.htm
Not something I want to tackle on my own, but just looking for stuff I need and can re-use.
PostPosted: Wed Apr 18, 2007 7:23 pm    Post subject: Reply with quote
A fancy spoooooooooohhhhnnn xmember.
Or make your own, not that difficult. There's also a guy on tg.o that builds 'em with humps to tuck up long tubes.
Is yours a stick or auto right now? Did you reuse the 305 starter when you swapped to the 350?
If auto, you'll need either 3rd or 4thgen pedals, you'll also need 4thgen slave and either 3rd/4th master cylinder.
You're going to have an issue with the speed sensor. The t56 is electronic and yours should be cable driven. So either swap to a newer 90-92 camaro guage cluster, buy one of those converter boxes, or mount up some autometers in your cluster.
Other than that, it'll bolt right up. I reused my stock starter, but that's because the typical 305 starter is smaller than the standard 350 starter.
Shrug
Driveline is the same length if you go with the stock bellhousing.
A new clutch is going to be pricey though. Stockers go for at least $250.
Oh yeah, then have fun banging gears!
305 302eater
PostPosted: Wed Apr 18, 2007 8:13 pm    Post subject: Reply with quote
I have also converted my car from a 700r to a lt1t56 if your car was a auto you will have to do some hole cutting and if you can i recomend using the third gen pedals rather then forth gen. I had forth gen pedals and i could never get them to mount right for me. I got my cross member from here www.skulte.com. It has worked fine for me. I would recomend getting a roller pilot bearing they are awesome and will last a lot longer then the bushing style. But ya have fun installing the trany man i know i did. And as ian said have fun banging gears! Very Happy
Thirdgenless
PostPosted: Wed Apr 18, 2007 8:45 pm    Post subject: Reply with quote
I've had both sets of pedals and I liked the 4thgen ones I've got now. Shrug
Besides, they were brand new and cheap. Smile
I've also heard mixed about the pilot bushing/bearing debate. I'm running a bushing and everytime I've pulled the trans it's pretty torn up.
PostPosted: Wed Apr 18, 2007 8:56 pm    Post subject: Reply with quote
There are any number of good resources on this swap out there BigDaddy:
http://www.skulte.com/T56.html
http://www.thirdgen.org/techboard/faq-board/229205-t56-swap-answers-questions.html
http://www.thirdgen.org/techboard/transmissions-drivetrain/342751-t56-scatter-shield-2piece.html
http://www.thirdgen.org/techboard/transmissions-drivetrain/342588-one-more-t5-t56.html?highlight=ls1+t56
http://www.sethirdgen.org/t56.htm
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=126/prd126.htm
Right now I've got about two grand total set aside for the swap and the other stuff the car needs, and I'm currently hunting down all the parts. I do have a question I'll throw out there to the guys who have already done this.
For the clutch: I still have the bolt-on L98 in my IROC pushing at most 240hp/340ft at the fly. It's also my daily (when it's running) so I neither want nor really need an overkill clutch that's going to grab and chatter in traffic, or cost me 1100 smackers. Any recommendations, or should I just pick up a stocker LT1 or LT4 clutch?
PostPosted: Wed Apr 18, 2007 8:58 pm    Post subject: Reply with quote
i read the article. the flywheel i have a 72 block is the flywheel going to be an after market or what what make and model should i look for.
PostPosted: Wed Apr 18, 2007 9:07 pm    Post subject: Reply with quote
ok so i have to used a centerforce flywheel for my block.
PostPosted: Wed Apr 18, 2007 9:08 pm    Post subject: Reply with quote
Summit sells Centerforce and McLeod LT1-style flywheels for 2-piece RMS engines. They're not cheap though.
PostPosted: Wed Apr 18, 2007 9:57 pm    Post subject: Reply with quote
Last time I looked for that 2 pc RMS flywheel cheapest I could find it was $390.
PostPosted: Wed Apr 18, 2007 10:37 pm    Post subject: Reply with quote
I'm running an LS1 T56
PostPosted: Wed Apr 18, 2007 11:00 pm    Post subject: Reply with quote
i am running a centerforce dual friction (90% more holding power then stock acording to centerforce) on my 240HP l98. it holds solid (never had it slip, even on the canada cruise when smoke was ouring out of amorgetRS's car at every shift) and it is nice to drive on the street. the car does see daily use.
305 302eater
PostPosted: Thu Apr 19, 2007 8:03 am    Post subject: Reply with quote
I'm running a bushing and everytime I've pulled the trans it's pretty torn up.[/quote]
From what I've been told the pilot bearing can really save your trany compared to a bushing. I figured I would put one in. They are only like 11 or 12 dollars from summit.
Thirdgenless
PostPosted: Thu Apr 19, 2007 8:07 am    Post subject: Reply with quote
I didn't know you could even get bushings anymore, I am pretty sure that GM is only selling bearings now. Maybe you can still get bushings in the aftermarket.
305 302eater
PostPosted: Thu Apr 19, 2007 9:26 am    Post subject: Reply with quote
I'm not sure. They shouldn't make bushings anymore.
Thirdgenless
PostPosted: Thu Apr 19, 2007 9:29 am    Post subject: Reply with quote
You can get bushings at part stores. They're better. They just wear down. When a bearing goes, it can take out the input shaft.
Running an LS1 - T56 with the adapter plate is cheaper in the long run. You use thirdgen bellhousing, pedals, hydraulics, flywheel, clutch.
Run a Spec 3 clutch and you'll be fine. The LT1 style clutchs don't hold as well and there are lots of complaints about the centerforce clutch on the LT1 Pull style clutch.
PostPosted: Thu Apr 19, 2007 9:36 am    Post subject: Reply with quote
Got a little off track in my last reply lol so:
For your LT1 style stuff.
You'll need a 2 piece LT1 Style flywheel. I saw them for $300. Centerforce makes one.
You'll need the pedals/hydraulics like Ian said.
You'll need a Pilot bushing of some sort. I don't know if you need an extended one or a standard one. Might want to measure.
You'll need a LT1 Style Clutch.
Specclutch.com
Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None
Product Number: SC421 SC422 SC423H SC423 SC423F SC424 SC425
Torque Capacity: 480 560 620 690 800 690 1050
Pricing: $399 $499 $591 $539 $688 $559 $639
Centerforce is cheaper, but like I said, I've heard problems.
I love my spec 3. I've gone through 2 axle shafts and a ring and pinion on slick and the clutch holds strong!
Page 1 of 3
