BigDaddyVu 12sec Club
Posted: Wed Apr 18, 2007 6:30 pm Post subject: t-56 ? |
| who in here has installed a t-56 in there 3rd gen |
Posted: Wed Apr 18, 2007 6:45 pm Post subject: |
Talk to Ian... _________________ '86 Trans Am - 5.0L TPI - LT1 cam - 700R4 - WS6
Posted: Wed Apr 18, 2007 6:48 pm Post subject: |
Also Twilightoptics. I'm sure there might be more. I'm wanting to do that with my 89 in the near (?) future. _________________ 92 Camaro
Posted: Wed Apr 18, 2007 7:06 pm Post subject: |
| the t-56 is out of a 97 ss camaro. drive line, cross member, and bellhousing is what came with it. what parts do i need to mate it to the engine |
Posted: Wed Apr 18, 2007 7:16 pm Post subject: |
Since I've been toying with the idea, I've done a little research on the internet and came across this article among others http://sethirdgen.org/t56.htm
Not something I want to tackle on my own, but just looking for stuff I need and can re-use. _________________ 92 Camaro
Posted: Wed Apr 18, 2007 7:23 pm Post subject: |
A fancy spoooooooooohhhhnnn xmember.
Or make your own, not that difficult. There's also a guy on tg.o that builds 'em with humps to tuck up long tubes.
Is yours a stick or auto right now? Did you reuse the 305 starter when you swapped to the 350?
If auto, you'll need either 3rd or 4thgen pedals, you'll also need 4thgen slave and either 3rd/4th master cylinder.
You're going to have an issue with the speed sensor. The t56 is electronic and yours should be cable driven. So either swap to a newer 90-92 camaro guage cluster, buy one of those converter boxes, or mount up some autometers in your cluster.
Other than that, it'll bolt right up. I reused my stock starter, but that's because the typical 305 starter is smaller than the standard 350 starter.
Driveline is the same length if you go with the stock bellhousing.
A new clutch is going to be pricey though. Stockers go for at least $250.
Oh yeah, then have fun banging gears! _________________
305 302eater Member
Posted: Wed Apr 18, 2007 8:13 pm Post subject: |
I have also converted my car from a 700r to a lt1t56 if your car was a auto you will have to do some hole cutting and if you can i recomend using the third gen pedals rather then forth gen. I had forth gen pedals and i could never get them to mount right for me. I got my cross member from here www.skulte.com. It has worked fine for me. I would recomend getting a roller pilot bearing they are awesome and will last a lot longer then the bushing style. But ya have fun installing the trany man i know i did. And as ian said have fun banging gears!  _________________ Thirdgenless |
Posted: Wed Apr 18, 2007 8:45 pm Post subject: |
I've had both sets of pedals and I liked the 4thgen ones I've got now.
Besides, they were brand new and cheap.
I've also heard mixed about the pilot bushing/bearing debate. I'm running a bushing and everytime I've pulled the trans it's pretty torn up. |
Posted: Wed Apr 18, 2007 8:58 pm Post subject: |
| i read the article. the flywheel i have a 72 block is the flywheel going to be an after market or what what make and model should i look for. |
Posted: Wed Apr 18, 2007 9:07 pm Post subject: |
| ok so i have to used a centerforce flywheel for my block. |
Posted: Wed Apr 18, 2007 9:08 pm Post subject: |
| BigDaddyVu wrote: | | i read the article. the flywheel i have a 72 block is the flywheel going to be an after market or what what make and model should i look for. |
Summit sells Centerforce and McLeod LT1-style flywheels for 2-piece RMS engines. They're not cheap though. |
Posted: Wed Apr 18, 2007 9:57 pm Post subject: |
| Last time I looked for that 2 pc RMS flywheel cheapest I could find it was $390. |
Posted: Wed Apr 18, 2007 10:37 pm Post subject: |
| I'm running an LS1 T56 |
Posted: Wed Apr 18, 2007 11:00 pm Post subject: |
| i am running a centerforce dual friction (90% more holding power then stock acording to centerforce) on my 240HP l98. it holds solid (never had it slip, even on the canada cruise when smoke was ouring out of amorgetRS's car at every shift) and it is nice to drive on the street. the car does see daily use. |
305 302eater Member
Posted: Thu Apr 19, 2007 8:03 am Post subject: |
I'm running a bushing and everytime I've pulled the trans it's pretty torn up.[/quote]
From what I've been told the pilot bearing can really save your trany compared to a bushing. I figured I would put one in. They are only like 11 or 12 dollars from summit. _________________ Thirdgenless |
Posted: Thu Apr 19, 2007 8:07 am Post subject: |
| I didn't know you could even get bushings anymore, I am pretty sure that GM is only selling bearings now. Maybe you can still get bushings in the aftermarket. |
305 302eater Member
Posted: Thu Apr 19, 2007 9:26 am Post subject: |
| Dewey316 wrote: | | I didn't know you could even get bushings anymore, I am pretty sure that GM is only selling bearings now. Maybe you can still get bushings in the aftermarket. |
I'm not sure. They shouldn't make bushings anymore. _________________ Thirdgenless |
Posted: Thu Apr 19, 2007 9:29 am Post subject: |
| 305 302eater wrote: | | Dewey316 wrote: | | I didn't know you could even get bushings anymore, I am pretty sure that GM is only selling bearings now. Maybe you can still get bushings in the aftermarket. |
I'm not sure. They shouldn't make bushings anymore. |
You can get bushings at part stores. They're better. They just wear down. When a bearing goes, it can take out the input shaft.
Running an LS1 - T56 with the adapter plate is cheaper in the long run. You use thirdgen bellhousing, pedals, hydraulics, flywheel, clutch.
Run a Spec 3 clutch and you'll be fine. The LT1 style clutchs don't hold as well and there are lots of complaints about the centerforce clutch on the LT1 Pull style clutch. |
Posted: Thu Apr 19, 2007 9:36 am Post subject: |
Got a little off track in my last reply lol so:
For your LT1 style stuff.
You'll need a 2 piece LT1 Style flywheel. I saw them for $300. Centerforce makes one.
You'll need the pedals/hydraulics like Ian said.
You'll need a Pilot bushing of some sort. I don't know if you need an extended one or a standard one. Might want to measure.
You'll need a LT1 Style Clutch.
Specclutch.com
Stage 1 Stage 2 Stage 2+ Stage 3 Stage 3+ Stage 4 Stage 5 None
Product Number: SC421 SC422 SC423H SC423 SC423F SC424 SC425
Torque Capacity: 480 560 620 690 800 690 1050
Pricing: $399 $499 $591 $539 $688 $559 $639
Centerforce is cheaper, but like I said, I've heard problems.
I love my spec 3. I've gone through 2 axle shafts and a ring and pinion on slick and the clutch holds strong! |
