doc76239 Member
Joined: 16 Dec 2004 Posts: 70 Location: Marysville,WA
Posted: Tue Feb 27, 2007 10:33 am Post subject: 9 bolt uprades |
So what should I up grade on my 9 bolt in my 89 formula? And not a 10bolt those things weigh a ton. _________________ My bird eats ponies |
Posted: Tue Feb 27, 2007 1:20 pm Post subject: |
| a 10 bolt is not an upgrade from a 9 bolt. 9 bolts are stronger. |
Posted: Tue Feb 27, 2007 2:18 pm Post subject: Re: 9 bolt uprades |
| doc76239 wrote: | | So what should I up grade on my 9 bolt in my 89 formula? And not a 10bolt those things weigh a ton. |
You know that 10th bolt doesn't really add that much weight.
In fact I'd have a hard time beleiving a 10 bolt weighs more than a 9 bolt. |
Posted: Tue Feb 27, 2007 2:32 pm Post subject: |
it's not so much the extra bolt as it is a bunch of leftover chunks from all the axles and pinions that have broken inside of it in the past...  |
Jenn Member
Joined: 03 Feb 2007 Posts: 362 Location: hangin with my boys
1987 Pontiac Firebird
Posted: Tue Feb 27, 2007 2:50 pm Post subject: |
that was harsh Tony
and there were no broken axles..... that was Paul.  |
Posted: Tue Feb 27, 2007 2:54 pm Post subject: |
| Xophertony wrote: | it's not so much the extra bolt as it is a bunch of leftover chunks from all the axles and pinions that have broken inside of it in the past...  |
LMAO, I think Paul only has an 8 bolt rear end. |
doc76239 Member
Posted: Tue Feb 27, 2007 4:42 pm Post subject: WHAT? |
rjmcgee are you high???? A 10 bolt weighs a lot more than a 9bolt. I should know I bought a car with a broken 9bolt, swapped it out for a 10 bolt cause that was all I could find. Rebuilt the 9 bolt and put it back in my firebird. There is a big differance in weight. Even more so if the 10 bolt has the cast iron calipers. _________________ My bird eats ponies |
Posted: Tue Feb 27, 2007 7:46 pm Post subject: Re: WHAT? |
| doc76239 wrote: | | rjmcgee are you high???? A 10 bolt weighs a lot more than a 9bolt. I should know I bought a car with a broken 9bolt, swapped it out for a 10 bolt cause that was all I could find. Rebuilt the 9 bolt and put it back in my firebird. There is a big differance in weight. Even more so if the 10 bolt has the cast iron calipers. |
No not high.
Just have a hard time believing that there is alot of weight differance. |
doc76239 Member
Posted: Tue Feb 27, 2007 9:34 pm Post subject: HAHA |
Some one want to help me out here. _________________ My bird eats ponies |
Posted: Tue Feb 27, 2007 10:14 pm Post subject: |
What are you looking to do doc? Just add a little strength or what?
Posted: Tue Feb 27, 2007 10:25 pm Post subject: |
| 10 bolts are heavy. chris and i ahve almost majorly injured ourselves and my firebird moving them around. the nine bolt seems like it is lighter.. but who knows. |
Posted: Wed Feb 28, 2007 1:26 am Post subject: |
I haven't touched your 9 bolt rear...even once!
the 10 Bolts have nothing on a 9" ford rear.....I've moved three of them from My garage to pickup truck bed...they're HEAVY........ _________________
