Jess Administrator
Joined: 24 Nov 2003 Posts: 429 Location: Mount Vernon, WA
Posted: Wed Feb 07, 2007 9:30 am Post subject: headlight assembly |
Not sure if the headlight motor is croaked as well, but the other day something in the arm that actually moves the light assembly on the drivers side of the GTA let go. Its ghetto rigged with a zip tie now just to hold the light up so I can drive at night.  _________________ '88 Formula
'95 Trans Am - Sold
'88 GTA - Sold
'89 Firebird V6 - Sold |
Posted: Wed Feb 07, 2007 9:36 am Post subject: Re: headlight assembly |
| Jess wrote: | | Its ghetto rigged with a zip tie |
Use # 724.  |
Posted: Wed Feb 07, 2007 6:49 pm Post subject: |
| Did I buy one from you before?? Anyway, I'll check to see which side I have. I did remove the motor though, but it was the only thing i used. |
Jess Administrator
Posted: Thu Feb 08, 2007 11:28 am Post subject: |
| Possibly, I had one at one time. I Should have held on to it! Thanks for checking. |
Posted: Thu Feb 08, 2007 7:47 pm Post subject: |
| Hey, Jess, I have a complete, minus motor, drivers side headlight assembly. It's even black. Do you want the whole thing or just the little arm? |
Jess Administrator
Posted: Fri Feb 09, 2007 9:13 am Post subject: |
| How much for the whole thing? It would be a lot easier (at least I think) to just replace the whole assembly rather than try and pull it apart and just change the arm. Now if the motor is toast, have to start looking for a new one. |
Posted: Fri Feb 09, 2007 1:13 pm Post subject: |
actualy that arm is cake to change while the assembly is in the car IIRC. in fact i think i had to remove it to get the motor out when my GTA was having issues.
BTW the only way the arm could realy be causing you trouble is if it fell off. if it is still attached and the light does not go up you have other problems. |
Jess Administrator
Posted: Fri Feb 09, 2007 5:25 pm Post subject: |
| The arm is broken where it connects to the motor. I have a zip tie holding the arm to the connection point. |
BigDaddyVu 12sec Club
Posted: Fri Feb 09, 2007 6:46 pm Post subject: |
I got a pair of 91 gta flip lights complete assembly it has those small square head lambs i was gonna put it on my 84 t/a but these have and extra wire and the bezel dosen't match my body lines. _________________
Posted: Fri Feb 09, 2007 9:03 pm Post subject: |
| Either way Jess. I have everything BUT the motor. If the arm just fell off I can pull that off and ship it easy enough. If you really want the whole thing, I've got that too. Let me know, I'll have Deb figure out some shipping. Price depends on what you want, just let me know. |
