scott in wa. Member
1988 Chevrolet Camaro IROC-Z
Posted: Mon Jan 08, 2007 7:21 am Post subject: memcal part numbers |
Well, we worked on some exhaust leaks Saturday, and then called it a night.
I did try another chip and wound up with CODE 51 again. Crap.
I guess I could have a few bad chips, tough to rule out, So Iam going to order 5 more new chips from moats.
Id like to Get a brand new Memcal as well but Iam having problems finding a part number, been searching the web, Will buy it from GM direct.
Where can I get the proper part number for our application?
That would be a 91 Camaro v8 tpi, auto car.
I think its broadcast code AUJP
Thanks
Scott |
scott in wa. Member
Posted: Mon Jan 08, 2007 7:47 am Post subject: hummmm? |
looks like
1990-1992 350 F-Bodies 16151348
DESCRIPTION: EPROM ELECTRONIC CONTROL MODULE (ECM)
This is the right part number if your ECM has 4307ANJF, 4312ANJ, 1350AUJP
Can anyone confirm ?
thanks
scott |
Posted: Mon Jan 08, 2007 9:13 am Post subject: |
| According to the threads on TGO, that part number is correct. |
