mrpopo573 Member
Posted: Fri Dec 29, 2006 11:24 am Post subject: Fuel Cell Gauge Installation |
Hi Guys! I have a technical question about my Jazz Fuel Cell.
It is completely installed and everything, but the on tank gauge is wired in the strangest manner. It is installed on top of what appears to be a magnetic pickup, the small diameter circle gauge sits in a metal dish that when rotated, causes the gauge to change its reading. the two leads coming out of the actual gauge lead to the stock gauge in my truck's dash. My problem is that this jazz gauge doesn't read correctly, as it never moves, only when i change its position like a clock on the metal dish. The jazz fuel cell is filled with a membrane as well, so I don't know if that matters for what replacement I get.
Ideas on how to fix? change? This problem. Thank you guys, hope this isn't too confusing.  _________________
2000 Maxima SE 5 Speed VQ30
