center console help
PostPosted: Mon Dec 18, 2006 3:44 pm    Post subject: center console help Reply with quote
So im in the process of replacing my carpet, got the seats out and now i can't figure out how the heck the center console comes out. i feel like a big dummy but i really can't figure it out. can someone lend advise?
PostPosted: Mon Dec 18, 2006 3:50 pm    Post subject: Reply with quote
Don't pull too hard. Wink
There are lots of little peices attached that you have to get to. Remeber, you have to take out the center storage section, to get to some of the bolts.
LB985IROC
1995 Chevrolet Camaro Z/28
PostPosted: Mon Dec 18, 2006 3:57 pm    Post subject: Reply with quote
the whole top comes off and you have access to all the fasteners
Cadillac of Bellevue
Retail parts sales
vee-six
PostPosted: Mon Dec 18, 2006 3:58 pm    Post subject: Reply with quote
john is absolutly correct. EDIT* as is lb985iroc
i'll put it into a little more detail for you.
first remove the torx screws around the radio/climatecontrol bezzle and remove it by pulling the right side out and sliding the bezzle towards the passanger side.
then remove the storage compartmant from the center console base. this may require removal of the lid but i think it does not.
now allong the front where the bezzle was, under the dash there are two medium size bolts (7-10MM not sure). remove those.
now, under the storage compartment you removed, remove the two bolts (10MM?) holding the base to the floor.
at this point you just need to remove the unit from the car without getting it cought o any wiring.
LB985IROC
PostPosted: Mon Dec 18, 2006 4:26 pm    Post subject: Reply with quote
yea well i was going to put up an eploded view of the console but my catalog will only let me print the picture
Retail parts sales
vee-six
PostPosted: Mon Dec 18, 2006 4:58 pm    Post subject: Reply with quote
haha. thanks for the help guys. got it out with minimal problems. so the interior is pretty much stripped, cept the seatbelts, those will require some serious muscle. ill get em tomorrow as well as actually pull the carpet.
