Convertible A pillar gage pod
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Tue Nov 21, 2006 12:15 pm    Post subject: Convertible A pillar gage pod Reply with quote
So will all the gage pods fit on a vert??? Or are they different???
Can’t seem to find any that are vert only.
Scott
PostPosted: Tue Nov 21, 2006 12:46 pm    Post subject: Reply with quote
Got some info from Dakota Digital, who also sells mounts and pods for their gauges. If you get the whole A-pillar with the gauge pods integrated, then they are different for Convertable, T-Top and Hardtop. If you get just the pod, which covers a portion of the pillar, then they are all the same.
http://www.dakotadigital.com/index.cfm/page/ptype=results/Category_ID=284/home_id=59/mode=cat/cat284.htm
scott in wa.
PostPosted: Tue Nov 21, 2006 12:49 pm    Post subject: sweet Reply with quote
good stuff.
thanks
PostPosted: Tue Nov 21, 2006 10:10 pm    Post subject: Reply with quote
FYI; a vert's a-pillar plastic is the same as a t-tops with the top cut off.
90droptoproc
PostPosted: Wed Nov 22, 2006 12:16 am    Post subject: Reply with quote
I second this, you should be fine with either a pod for your stock pillar or a whole new pillar with pods already molded in, but you will need to cut the top off to match your old one
