V6 Hydrolic T-5
PostPosted: Fri Sep 29, 2006 9:52 am    Post subject: V6 Hydrolic T-5 Reply with quote
I want a V6 T-5 with Hydrolic bell housing. If you have one you want to part with let me know! I could modify a WC-T5 (I ownone ) to fit if you want to sell me a blown T-5 with the above requirements.
Thanks!
PostPosted: Fri Sep 29, 2006 11:03 am    Post subject: Reply with quote
the belhousings actualy seperate from the tranny case, so all you realy need is the belhousing then right?
PostPosted: Fri Sep 29, 2006 12:06 pm    Post subject: Reply with quote
the cases mount identical, but the input shaft on the V8 is 26 spline or whatever, so the input shaft would have to be swapped. Plus the gearing is a little different. So I could use a V6 hydrolic bellhousing as well, plus the flywheel and clutch. You have?
PostPosted: Fri Sep 29, 2006 1:01 pm    Post subject: Reply with quote
no i don't. i was just trying to figure out what it is you need.
but i am confused. you have a v6 tranny on the car now with a hydrolic bellhousing correct? and you have a v8 trannsmission you want to bolt on to the car? you can bolt a v8 t5 to a v6 bellhousing. the tranny bolt patterns are the same. it is only the bellhousing to block pattern that is different. (and the splin/input shaft of course).
so why do you need a new bellhousing?
PostPosted: Fri Sep 29, 2006 2:25 pm    Post subject: Reply with quote
Duh I have a V6 automatic! Lol!
Here's the parts I own.
V8 WC-T5
S10 V6 cable T5
2ea 700r4's
The S10 V6 case wont work. Bellhousing is cable. No go. So, i need a V6 camaro T5 with a hydrolic bellhousing, OR, i can mate a hydrolic V6 bellhousing to the WC-T5. Make sense?
PonchoTA
PostPosted: Fri Sep 29, 2006 3:07 pm    Post subject: Reply with quote
I have a T-5, V6 bellhousing, with the ear for the hydraulic clutch if that's what you need...
PM me!
Paully
PostPosted: Sat Sep 30, 2006 1:09 am    Post subject: Reply with quote
ohhhhh...... ok i understand now.
wanarunhard
PostPosted: Sun Oct 29, 2006 12:09 am    Post subject: v6 Reply with quote
k i have a v6 5speed i think im going v8 with mine wanna swap?
i need v8 hyd trans have pressure plate and all mine is hyd
