Posted: Thu Oct 19, 2006 12:59 pm Post subject: 10 bolt upgrade parts GP. |
Linking to FRRAX.
http://www.frrax.com/rrforum/index.php?showtopic=8546
Figured I would pass it on, in case anyone was in the market.
| Quote: | I've put together an upgrade package for the 3rd/4th gen Fbods - 3rd gens especially will break axles under the stress of RR duty, and I've cracked a 4thgen axle. Dragstrip use with slicks will break them, too.
These axles are direct replacement, use OEM wheel bearing and seals (not included) and fit any of the popular diffs (also not included).
Package includes:
1 Pair Superior Replacement Series axles http://www.superioraxle.com/pdffolder/supe...catalog2004.pdf on p17
10 ARP 2.5" long wheel studs, pressed in place
10 Gorilla short, open bulge lugnuts
Cost is $185, plus shipping plus CA sales tax on orders shipped to CA address.
specify model year:
3rd gen 1990-1992
4th gen 1993-1996
4th gen 1998-2002
questions/comments PM me or email me at ablaine (at) cruzio (dot) com or call me at 831 427-3296 evenings PST
Regards,
Alan Blaine
Blaine Fabrication |
Posted: Thu Oct 19, 2006 5:55 pm Post subject: |
Now if they could figure out something about that pinion gear....
Raiden Member
Posted: Thu Oct 26, 2006 7:34 am Post subject: |
| Twilightoptics wrote: | Now if they could figure out something about that pinion gear....
AMEN BROTHER! I busted my rear end and the only thing that broke was the pinion gear! I got the howeling noise for about 10 miles and then it was done! I got a junk yard rear end, welded the axel tubes and put the rear end diff. cover on for bearing support. Seems to be holding for now;) |
Posted: Thu Oct 26, 2006 7:57 am Post subject: |
| Twilightoptics wrote: | | Now if they could figure out something about that pinion gear.... |
You could always find a 8.5" and weld the spring/shock/ta brackets on. |
Posted: Thu Oct 26, 2006 5:30 pm Post subject: |
Ehh, rear girdle is overrated.  |
Posted: Thu Oct 26, 2006 10:57 pm Post subject: |
| rjmcgee wrote: | Ehh, rear girdle is overrated.  |
So are slicks  |
Posted: Fri Oct 27, 2006 8:03 am Post subject: |
| Twilightoptics wrote: | | rjmcgee wrote: | Ehh, rear girdle is overrated.  |
So are slicks  |
Posted: Fri Oct 27, 2006 8:45 am Post subject: |
Ouchie!
Posted: Fri Oct 27, 2006 4:52 pm Post subject: |
ouch
Posted: Fri Oct 27, 2006 7:02 pm Post subject: |
This threads bout polishing turds anyway aint it??  |
