chevy heads big valves 140.00
wanarunhard
PostPosted: Thu Nov 16, 2006 7:01 pm    Post subject: chevy heads big valves 140.00 Reply with quote
k stock chevy heads big valve 194 intake maybe 202 not sure ready to run 140.00 will deliver maybe depends where i go to portland a lot so hit me up casting no is as follows 93417369 and then it says gm11 also 320 under the valve cover
PostPosted: Thu Nov 16, 2006 7:56 pm    Post subject: Reply with quote
Whats the casting number?
wanarunhard
PostPosted: Fri Nov 17, 2006 8:06 pm    Post subject: heads Reply with quote
k can any one tell me what theses casting numbers mean?
PostPosted: Fri Nov 17, 2006 8:58 pm    Post subject: Reply with quote
I think you'll find thats a 33417369. Thats a Hecho en Mexico replacement head that came on a low performance crate motor. It has 76cc combustion chambers so it will keep compression pretty low too.
You can look up casting numbers on www.mortec.com
PostPosted: Fri Nov 17, 2006 9:36 pm    Post subject: Re: heads Reply with quote
They mean the differance between a low performance engine and something that runs strong. Valve size doesn't really matter with SBC's when it comes to IDing heads.
wanarunhard
PostPosted: Sun Nov 19, 2006 5:48 pm    Post subject: heads Reply with quote
ok so i got the motor that these heads came on so its a good possibility that it a crate motor right?
PostPosted: Sun Nov 19, 2006 5:56 pm    Post subject: Reply with quote
Define "crate" motor.
Cause you can have a "crate" motor, that is in no way shape or form a "performance" motor.
PostPosted: Sun Nov 19, 2006 7:25 pm    Post subject: Reply with quote
If the blocks a match it should say hecho en mexico on the back near the bellhousing. Those heads and the mexican block come from the low performance crate engine. They're usually rated 210hp gross and have 4 bolt mains. The 290 hp and up motors are the performance motors. Those blocks will be canadian or US.
wanarunhard
PostPosted: Mon Nov 20, 2006 12:22 pm    Post subject: heads and block Reply with quote
ok i didnt see made in mexico anywhere on the block but low performance crate motor right? would be reliable workhorse though
PostPosted: Mon Nov 20, 2006 9:12 pm    Post subject: Reply with quote
Ya. those motors are great pullers. Put it in a pickup and it'll run a very long time. Low compression so they'll burn crap gas too. Or swap cams and heads and it can be made into a performer.
PostPosted: Mon Nov 20, 2006 9:48 pm    Post subject: Reply with quote
I thought there were some machining tolerances or that it was kind of a crappy casting or something that made the mexi blocks crappy?
PostPosted: Mon Nov 20, 2006 10:21 pm    Post subject: Reply with quote
It's their castings. They're great the first time through. But they really need to be checked for core shift if you're going to bore. There's alot of extra iron in them so they're heavy. I think they do this just to make sure that if the castings off there's still enough metal. The one I have they actually had to grind on the sides of the valley to make room for the lifters to drop in their holes. The american blocks don't even come close to being in the way. I've heard that if you find one without alot of shift, becuase of the extra iron they're a tough motor. Just looking at the differences between my hecho en mexico block and my others, i've always rebuilt the american blocks. Someday if i'm desperate, I might do my mexican one.
wanarunhard
PostPosted: Mon Nov 20, 2006 11:57 pm    Post subject: heads and block Reply with quote
ok nobody thinks these are worth a mexican taco right? so enough history lesson and just delete this thread please ill just throw in whole motor with the camaro i have up for sale maybe some one wants to do a v8 swap on it
