timing???
jakemk8706
PostPosted: Tue Sep 05, 2006 5:31 pm    Post subject: timing??? Reply with quote
what would be the optimal timing degree to run on my 5.7 TPI? now iv read in the performance books i have that it does good around 10 12. mines at 8 degrees above TDC so what would be the best thing to do
gas brake dip dip
PostPosted: Tue Sep 05, 2006 6:42 pm    Post subject: Reply with quote
Depends on what gas you want to run, what thermostat you run, and what chip you run.
PostPosted: Tue Sep 05, 2006 6:53 pm    Post subject: Reply with quote
It depends on the engine itself.
You could run more timing and it seem okay, but you could be knocking and the ECM pulling the same timing you added. You'd need a scan tool of some sorts to monitor that.
If it's stock, put it at 6-8deg BTDC and call it good.
