Jules91Z28 New Member
Posted: Mon Mar 08, 2004 8:29 am Post subject: code 24 question |
| Hi , I am not great at posting but I have a question for those that remember me I have a 1991 Z28 and its giving me the code 24 VSS so I called the mechanic and he said my car dont have a speed sensor somthing about in the dashboard , my speedo dont work untill the car has been running awhile ?? and once my tach started jumping and couldnt keep it running but no new code was set?? and it never did that again if anyone has any ideas it would be great. thank you |
Posted: Mon Mar 08, 2004 8:33 am Post subject: |
you do have a VSS, all the 90-92 camaros have electronic speeds, with a VSS sensor in the tailshaft on the tranny, it is possible for it to go bad. you can try replacing the sensor, and see what that does.
also, out of curiosity, does your speedo read correctly? if it does, a new VSS may not fix it, the issue may be in the computer. |
Posted: Mon Mar 08, 2004 7:23 pm Post subject: |
| thanks for the help , I dont beleive the speedo is correct. It bounces around alot then my service engine light soon comes on I called a dealership to order the sensor and they told me I dont have one he supposedly called chevrolet, I dont know I hate to spend the money on a mechanic again when a sensor could just be changed, I have the service manual for my car from a dealership repair shop but I think you need a class just to read the darn thing ..... I will try to talk my hubby into jacking it up again and looking , thank you |
Posted: Mon Mar 08, 2004 7:39 pm Post subject: |
| With the speedo bouncing around too, i'd almost bet its the sensor. It's super easy to change too. You should be able to pick one up at good autoparts stores too. The sensor goes in the hole at the back of the trans where the speedo cable used to go. It's held in with a single bolt and a clamp.. Should have 2 wires going to it. You may have to pull the sensor out and take it with you to get the right one though. I believe they made 3 different ones depending on what gear ratio was in your rear end. |
Posted: Mon Mar 08, 2004 8:12 pm Post subject: |
| When I had my speedo cable unplugged, it took about 15mi till it set a code. Though mine is a cable not electric. |
Posted: Tue Mar 09, 2004 4:11 am Post subject: |
| brandon, i thought they all used the same sensor, since they are diffrent speedo gears that drive it. IIRC they are all like 2k pulses-per-mile. |
Posted: Tue Mar 09, 2004 9:00 am Post subject: |
| I am so frustrated , why is it not in any of the books for the part number , going to try nappa later today , I tried schucks , a actual chev dealer they all think I am a stupid girl who knows nothing I asked why would my car give a code 24 which says VSS if i didnt have one????? thanks |
Posted: Tue Mar 09, 2004 9:07 am Post subject: |
i beleive the GM part number is
10456087
if brandon is correct (which he usualy is) i don't know if that is the correct one for your appliction.
is your car a 5speed or auto? i am pretty sure that that part number is for a 5speed car.
it might give you something to work off of though, although the GM list price on that is $94 and some change  |
Posted: Tue Mar 09, 2004 9:57 am Post subject: |
| thank you !! its a automatic do you recomend a place to order it ?? |
Posted: Tue Mar 09, 2004 9:58 am Post subject: |
if you can verify that IS the correct part number.
gmpartsdirect.com
i beleive it is only like $50 from them. but before you order, call a dealer, find out if that is in fact the right one. you might also pull the sensor you have, and head to a dealer with it, then you can confirm what you need. |
90RSrocks Member
Posted: Tue Mar 09, 2004 10:12 am Post subject: |
I've gotten more incorrect parts and bad advice from Chevy dealerships than anywhere else. I think the only prerequesite for working in the parts dept is a pulse.  |
Posted: Tue Mar 09, 2004 10:17 am Post subject: |
| 90RSrocks wrote: | I've gotten more incorrect parts and bad advice from Chevy dealerships than anywhere else. I think the only prerequesite for working in the parts dept is a pulse.  |
they are the ones that said I dont even have one !!! |
Posted: Tue Mar 09, 2004 10:33 am Post subject: |
ok sounds dumb but how do I know if I have a Lo3 5.0 v8
or a LB9 5.0 ?? I know its a vin F thanks again |
Posted: Tue Mar 09, 2004 10:35 am Post subject: |
| VIN F is LB9 |
L03 is TBI
LB9 is TPI Vin F |
Posted: Tue Mar 09, 2004 7:36 pm Post subject: |
| John when you change the rear gears the speedo gear ends up having to be different sizes to keep the right # of pulses per mile. Since the gear ends up being bigger the center of the shaft has to be moved away from the transmissions tailshaft to accomodate. This is why theres 3 sensors. No real change in the sensors other than the shaft is more ofset on some of them. |
Posted: Tue Mar 09, 2004 7:59 pm Post subject: |
Just went to the online Napa site. They show 3 different speed sensors.
Part# VSS207 Should be for an automatic. Original is stamped with a D81. $31.49
Part# VSS206 Again should be for an auto. Original is stamped with a D8N. $58.49
The only one that didn't say auto was part # VSS218 Stamped with #D8G or D8M.. $71.49
I wouldnt take the auto/stick part of the catalog as gospel. Our catalogs are wrong all the time on things like that. Look at your original and see what the stamping #'s are. If your luck is like mine it'll be the $71.49 one. |
Posted: Tue Mar 09, 2004 8:12 pm Post subject: |
you guys are awsome thank you all so much , after much begging and threatening to find me a new husband he pulled it out tonight and picked up the part and works great now !!!!!!!! and I called my chev mechanic and told him you guys all helped and his computer was stupid saying I didnt even have one anyway thanks so much and looking forward to some gatherings |
Red91RSCamaro Member
Joined: 01 Feb 2004 Posts: 60 Location: Hillsboro, OR
Posted: Mon Mar 22, 2004 5:16 pm Post subject: |
I wish I would have read this thread a few days ago seeing that my stupid VSS cable came unplugged from the sensor. There was a really easy way to find out which one you needed just by looking at your RPO codes inside your console (that's how I found mine). I just hope I never have to replace the stupid thing seeing that it is the $71 dollar one.
Thanks to Mike G. for crawling under my car and finding that the cable was disconnected, saved me a few bucks. |
