ongoing battle to get my 2.8 working correctly.
PostPosted: Sat Aug 19, 2006 10:03 am    Post subject: ongoing battle to get my 2.8 working correctly. Reply with quote
so the only "problem" my 1986 firebird still has running wise is this issue i have had for a while. it was dieing whenever i let the RPMs come down to idle. i thought it was an IAC. when i had my intake off i cleaned the TB IAC passages, and cleaned the IAC. the problem was almost gone. almost. now instead of dieing every other time i stopped it would die once or twice a trip. i went ahead and replaced the IAC with a new one. the problem is still present. it dies when the engine is coming down from cruise back to idle. but it only happens every once in a while. like once or twice in a twenty minute in town trip.
does anyone know what this could be?
the IAC is brand new.
the TPS is new about a year ago.
the MAF is new about 7 months ago.
cap and rotor are new about three weeks ago (broke cap when i had intake off)
can anyone help me? it is quite emberassing when i come to a stop and then have to re-start my car. Sad
PostPosted: Sat Aug 19, 2006 2:27 pm    Post subject: Reply with quote
Any holes or fractures in vaccum hoses? One vaccum hose routed improperly perhaps?
Manifold leak of some kind?
My fairlane does it too when its cold. I blame that mostly on the crappy choke on it though.
PostPosted: Sat Aug 19, 2006 2:48 pm    Post subject: Reply with quote
well, i was quite carefull in preparing my gasket surfaces, and i am almost certain i routed my vaccume hoses corrctly, but i'll take another look the next time i have the hood up. while i had it all apart i inspected all the lines and those not in good shape were replaced with extra hose i had on hand.
maniflod leak.... that would allow unmetered air into the intake, (or in worst case, oil and water into places they should not be) i see no evidence of oil or water leaks in the manifold, but air.... would that cause it to die randomly like it is doing?
Danked
Banned
PostPosted: Sat Aug 19, 2006 10:31 pm    Post subject: Reply with quote
i dont see why it wouldnt, when too much air is sucked into the engine without a sufficient amount of gas to compensate, it runs funny, it would explain alot. sorry if this means nothing, im just trying to help
PostPosted: Sat Aug 19, 2006 10:58 pm    Post subject: Reply with quote
Have you run a vac. gauge on it yet?
PostPosted: Sun Aug 20, 2006 11:46 am    Post subject: Reply with quote
no i have not. my dad has one though, so i will get around to it.
PostPosted: Sun Aug 20, 2006 12:18 pm    Post subject: Reply with quote
Could be a sticking EGR valve too. Disconnect it and see if the problem continues.
PostPosted: Sun Aug 20, 2006 9:03 pm    Post subject: Reply with quote
that makes ALOT of sense as it always happens when i am coming down from cruise. and that is when the EGR is active. good thinking brandon, i'll bet that is what it is.
PostPosted: Sun Aug 20, 2006 9:11 pm    Post subject: Reply with quote
Does it happen when the car is first warming up?
PostPosted: Sun Aug 20, 2006 11:12 pm    Post subject: Reply with quote
no. only once warm. which further points to EGR as a manifold vaccume leak would be prety undiscriminitory, as would a leak in the rest of the vaccume system. hmmm.. might be time to remove my EGR. (yay, a cleaner engine bay, and less carbon in my TB, booo not as good of gas mialage.)
PostPosted: Mon Aug 21, 2006 10:23 am    Post subject: Reply with quote
Yup. My IROC was doing the same thing before I parked it. Which reminds me, I need to call Scott about that valve.
