85 T/A WS6 Member
1985 Pontiac Trans Am
Posted: Thu Jul 27, 2006 7:07 am Post subject: 5-30W ? |
Here is a dumb question, I need to get some oil and was wondering what the proper weight is for a 305..
Im at work now otherwise I would pull out my manual... _________________
Posted: Thu Jul 27, 2006 7:54 am Post subject: |
| Mine lists 5-30 on the oil cap. I usualy use 10-30 though. it the summer, you could probably go even a little heavier, but with either 5-30 or 10-30, you should be fine. |
