82-92 Firebird Camaro Manual Transmission 1990
kurfbird
PostPosted: Fri Jun 23, 2006 8:21 am    Post subject: 82-92 Firebird Camaro Manual Transmission 1990 Reply with quote
This is everything to do a V8 auto to manual trans swap. Includes FLywheel, clutch, Slave cylinder, Trans, Drive shaft, Shifter etc.
400.00
kurfbird
1991 Camaro 3.1 v6
1991 Firebird 3.1 v6
1992 Formula 350 5.7
700r4 Transmissions
brucesthirdgenparts.com
PostPosted: Fri Jun 23, 2006 10:43 am    Post subject: Reply with quote
shouldent the driveshafts be the same auto or manual?
kurfbird
PostPosted: Fri Jun 23, 2006 10:48 am    Post subject: Drive shaft. Reply with quote
WOuld rather be safe than sorry. And include the drive shaft.
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Fri Jun 23, 2006 10:55 am    Post subject: Reply with quote
cool.
Faded
PostPosted: Fri Jun 23, 2006 3:52 pm    Post subject: Reply with quote
The driveshafts between an auto and manual are the same.
kurfbird
PostPosted: Fri Jun 23, 2006 4:19 pm    Post subject: thanks Reply with quote
thanks
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Fri Jun 23, 2006 4:51 pm    Post subject: Reply with quote
The drivelines in thirdgen are the same between a T5 and 700R4.... not the 200R4 or Th350(unless 9" tailshaft)
PostPosted: Tue Jul 04, 2006 12:38 pm    Post subject: Reply with quote
kurfbird, do you still have this? How much would it be without the driveshaft?
kurfbird
PostPosted: Tue Jul 04, 2006 1:00 pm    Post subject: Yes I still have it Reply with quote
Yews I still have it. Xophertony is suspose to pick it up next weekend. Price is 400.00 with or without drive shaft
kurfbird
1991 Camaro 3.1 v6
700r4 Transmissions
PostPosted: Tue Jul 04, 2006 1:10 pm    Post subject: Reply with quote
If Tony has dibs on it, it's cool.
Tony, are you dropping that in the GTA, or are you going to replace the one in the 6?
PostPosted: Tue Jul 04, 2006 9:09 pm    Post subject: Reply with quote
it's for the GTA. the v8 and v6 trannys are not bolt-on compatable (it can be done, but requires a custom clutch). also, kurfbird, does satarday work for you?
PostPosted: Tue Jul 04, 2006 9:35 pm    Post subject: Reply with quote
Rolling Eyes Couldn't find a 700R4 to swap in, apparently can't find a T-5/6 either. I'm seriously begining to doubt I'll get my car running by the end of summer.
Tony, when are you planning the swap? If it's soon, I might drive down there and lend a hand. I kinda want to see if pulling a T-5/6 swap in the IROC is something I could do myself.
PostPosted: Tue Jul 04, 2006 9:44 pm    Post subject: Reply with quote
i don't actualy have a plan for that yet. i would like to get a crossmember and tourque arm from spohn (so i can get the TQ arm off the tranny) 1st. but i am not sure. why, you want my old 700r4?
i would love, and could use all the help i can get. i realy have no idea what even needs to be done yet. i should probably start researching this swap.
I just bought a complete T5 swap in Portland for $100.Plus it came with extra's, like the whole running car. You needs to look harder.
PostPosted: Tue Jul 04, 2006 9:45 pm    Post subject: Reply with quote
so you are going to part that sucker out eh rod?
PostPosted: Tue Jul 04, 2006 9:48 pm    Post subject: Reply with quote
I thought you only needed to swap crossmembers for a T-56. Confused
Barely enough room for my current two cars. No way I can get another one for parts. Bashy Bashy
