TPI Throttle Body
PostPosted: Thu Jun 15, 2006 12:23 pm    Post subject: TPI Throttle Body Reply with quote
Need a Tuned Port-style TB for an '87 350 with MAF. Prefferably the entire thing, but at the very least I need the bottom half with the IAC port, and the coolant passage.
Would preffer local pickup around Pierce County, since I need it now. Will pay cash or PayPal if shipped.
PostPosted: Thu Jun 15, 2006 4:49 pm    Post subject: Reply with quote
Well, I might be able to reuse mine. I'll find out tomorrow.
PostPosted: Fri Jun 16, 2006 8:07 am    Post subject: Reply with quote
I think I've got my old one somewhere. No coolant passages though, so you'd need to do the throttle body coolant bypass (just connect the two hoses that went to the throttle body to themselves.
PostPosted: Fri Jun 16, 2006 11:34 am    Post subject: Reply with quote
unless it is below freezing most of the time you do not need throttle body coolant passqges.
PostPosted: Fri Jun 16, 2006 1:55 pm    Post subject: Reply with quote
I'm going to try and reuse mine. I'm doing a coolant bypass while I'm doing this, so it's no biggy.
If mine wont go together, I'll post back here.
PostPosted: Fri Jun 16, 2006 5:51 pm    Post subject: Reply with quote
Works fine. Don't need a new one. Thanks, all.
