700R4
PostPosted: Mon May 15, 2006 10:08 pm    Post subject: 700R4 Reply with quote
This is out of Bobby's Berlinetta. Allegedly has a Vette Servo in it.
Xophertony kind of has dibbs on that, but the whole tranny with his stock GTA's servo will be included on the transmission. Comes as a whole setup, this includes:
Transmission
Shifter cable
Shifter and plate
Torque converter
Crossmember
Allegdly it might need a new throttle valve cable. I can't confirm any of this yet.
Due to the size/bulkiness of the item, its gonna be local delivery/pickup only. I can have it out by Cows if anyone who's gonna be there who wants it.
I'm hoping for at least $60.
Last edited by Quasi-Traction on Mon May 15, 2006 10:27 pm; edited 1 time in total
PostPosted: Mon May 15, 2006 10:21 pm    Post subject: Reply with quote
I'll take it..
PostPosted: Tue May 16, 2006 8:18 am    Post subject: Re: 700R4 Reply with quote
Tell Tony to buy a new one. They are pretty inexpensive. Used transmission parts.... that aren't like gears and shafts.... bad idea.
PostPosted: Tue May 16, 2006 9:36 am    Post subject: Reply with quote
noted.
i was trying to keep my initial idea of spending NO money building up my 700r4. Rolling Eyes
PostPosted: Tue May 16, 2006 9:46 am    Post subject: Reply with quote
Transgo:
SKŪ700-Jr THM 700R4 85-up
Corrects/Prevents/Reduces: FIXES late shifts - Sticking TV Valve. 3-4 clutch failure; soft or slide-bump 1-2; 2-3 cutloose; shuttle 4-3-4-3; soft or late 4th. FAST- Easy installation!
http://www.transgo.com/contact.php
They used to have a kit that had the vette servo in it. There are LOTS of choices. These kits go for under $100.
PostPosted: Tue May 16, 2006 9:48 am    Post subject: Reply with quote
sounds nifty. is it less then $50 ?
EDIT... oh.
PostPosted: Tue May 16, 2006 11:47 am    Post subject: Reply with quote
chevymad wrote:
I'll take it..
Cool, I'll take it out and bring it with me to Cows.
PostPosted: Tue May 16, 2006 5:53 pm    Post subject: Reply with quote
I like the $10 edit.... no problem though. If you want you can resell the shifter and cable assembly to someone else. Crossmember as well. If you have it though I'd like the carberator bracket that holds the upper end of the tv cable.
PostPosted: Wed May 17, 2006 1:07 am    Post subject: Reply with quote
I'll include it. You can have the X-member too. I'm going to a manual trans, so I won't need it.
If you can give me a good Quadrajet in rebuildable shape that has a Electric choke and Mixture adjustment screws on the baseplate (basically one before 1981) You can have the Transmission free.
PostPosted: Wed May 17, 2006 4:52 pm    Post subject: Reply with quote
I believe I have one rebuildable quad i'm willing to part with. Came of a 78 crewcab 350. I'll check it out tonight. I'm not parting with my 454 quad though.. not sure where that might end up. I really don't want the rest of the stuff LOL. Shifter plate I might use. But I allready have my stock shifter hangin on the wall.. and the xmember will end up in my scrap pile. If its just scrap to you guess it wouldnt hurt nothing.. Gotta haul scrap away someday.
PostPosted: Wed May 17, 2006 7:01 pm    Post subject: Reply with quote
Ya, i've got a decent quad. Its off the 78. I took it off because I allready had a rebuilt one to put on, and this one seemed to have a sinking float. Typical for them.
PostPosted: Thu May 18, 2006 10:13 am    Post subject: Reply with quote
As long as it has the fuel inlet filter on the side and the "L" shaped chevy throttle linkage, mixture screws on the baseplate, were golden. Rebuilding's not a problem, I have about 4 Q-jets I can borrow parts from.
PostPosted: Thu May 18, 2006 7:30 pm    Post subject: Reply with quote
I think its what you want. Look it over when you get here. Otherwise I'll pay for the trans. I took it off a running truck.. last summer i believe. Spring I guess.. had the green beater running for cows.. this is off that engine.
