Posted: Wed May 10, 2006 9:15 am Post subject: I'm a man and I can be wrong. |
""When you make assumptions, you make an ass out of you and me"
So, I learned something today that I was rather delighted about with my 84' V6 (No, the Cylinder head didn't just magically repair itself)
I think I have a 3.42 rear.
I knew it didn't have posi, but always assumed the gear ratio for the 84 SC's with a 5 speed was a 3.08:1 and that Automatic 2.8's in 84 got 2.73's.
Apparently not.
According to the RPO sticker (which is orginal to the car and was removed from my old console by me and re-adhered to my new console) I have GU6 as my axle code, which should be a 3.42
This was further verified by TGO in there Tech Data Section saying that the Manual Trans LC1 V6 cars came from the factory with 3.42's.
Posted: Wed May 10, 2006 9:22 am Post subject: |
| I thought most of em came with 3.42s? Bart's old car slinky was a 2.8 MPFI Auto with 3.42s |
Posted: Wed May 10, 2006 10:50 am Post subject: |
Yup, I had an 83 Bird with the 2.8 and it had a 3.42 rear. It died a horrible death a couple years ago. Of course the Bird went through hell for the couple weeks that I had it before parting it out. Did a little wheeling.  |
Posted: Wed May 10, 2006 11:09 am Post subject: |
| chris we have totally talked about this. the talest gears v6s got were 3.23:1 in the M5 MPFI cars. |
Posted: Wed May 10, 2006 11:51 am Post subject: |
| Uhh.... why not just spend 15 minutes of your life jacking up the back of the car and reading the codes? |
Red91RSCamaro Member
Joined: 01 Feb 2004 Posts: 60 Location: Hillsboro, OR
Posted: Wed May 10, 2006 1:36 pm Post subject: |
| Twilightoptics wrote: | | I thought most of em came with 3.42s? Bart's old car slinky was a 2.8 MPFI Auto with 3.42s |
My '89 2.8 little V6 had the 3.42's in it as well. _________________ Wife: The smellier the car is, the faster it goes right? |
Posted: Wed May 10, 2006 2:11 pm Post subject: |
| Wow, you are still around dude? Got another thirdgen yet? |
Posted: Wed May 10, 2006 2:13 pm Post subject: |
| Xophertony wrote: | | chris we have totally talked about this. the talest gears v6s got were 3.23:1 in the M5 MPFI cars. |
1984 Camaro Sport Coupe
Firebird Sport Coupe
Transmission: Borg Warner Manual 5 speed
TH700R4 Automatic
Engine: 2.8L Carburated V6 (173ci, RPO: LC1)
Compression: 8.5:1
Horsepower/Torque: 107hp @4800rpm/145 ft/lbs @2100rpm
Rear Gearing: Manual 5 speed: 3.42:1(GU6)
Automatic 4 speed: 3.23:1(GU5) _________________
Posted: Wed May 10, 2006 2:15 pm Post subject: |
| Asdfga3 wrote: | | Uhh.... why not just spend 15 minutes of your life jacking up the back of the car and reading the codes? |
because then I have to decipher the Casting number to find the gear ratio. It'd probalby only then tell me if it was a 2 series or 3 series carrier. _________________
Posted: Wed May 10, 2006 2:36 pm Post subject: |
so when it's gears the "taller" of the two gear ratios: 3.42:1 and 3.23:1 wuld be 3.23:1 right? or did i mix that up?
Red91RSCamaro: a fellow hillsboronianite  |
Posted: Wed May 10, 2006 2:56 pm Post subject: |
Taller gears: 2.73's
Shorter gears: 4.11's
Hope that clarified. _________________
Posted: Wed May 10, 2006 3:25 pm Post subject: |
| oh, so yeah, 3.23s are the tallest gears in a 2.8. thanks. |
Posted: Wed May 10, 2006 4:17 pm Post subject: |
| My '89 V6 had 3.42 gears. In fact if anybody is looking for an axle it's for sale and it's cheap. |
PonchoTA Member
Posted: Wed May 10, 2006 7:40 pm Post subject: |
If you open the diff (you need to change the fluid anyway, right?!!) spin the axle until the markings on the ring gear come around, the exact number of teeth of the set will be stamped right on the gear, leaving NO chance of error. Should be 41,12
hth _________________ Paully |
Posted: Thu May 11, 2006 7:49 am Post subject: |
| Dewey316 wrote: | | Wow, you are still around dude? Got another thirdgen yet? |
Yeah, I am still around No new 3rd gen yet, but I did see my old red one drivin around the area the other day, it brought a tear to my eye. I miss my car and hangin with the crew.
I'm still driving around in the family sedan (ford tauras). I'm still living in Hillsboro. My kid is getting fricken big, he is almost 2 now, oh and I am still married . I will watch the forum a bit more to find out when you guys roll out to PIR or for gatherings in the Portland area. Would like to see ya'll again.
~Paul _________________ Wife: The smellier the car is, the faster it goes right? |
