ABSOLUTELY FREE MOTOR... come and get it.
PostPosted: Tue May 09, 2006 5:29 pm    Post subject: ABSOLUTELY FREE MOTOR... come and get it. Reply with quote
2.8L 60 degree V6. Carburated.
Everything is disconnected except the transmission and motor mounts. Bring your own Engine hoist. I will do most of the labor to help remove the motor.
Complete from flywheel foward.
Bellhousing and pressure plate included.
Starter and Solenoid included.
Extra Igntion coil and spark plug set included.
ECM and emission wiring harness included. (also compatable with S-10 and Blazers from 82-88)
Powersteering pump and hoses included.
Distributor, plugs and wires included.
Air conditioning compresser, cooler and AC Box included.
Smog pump included.
Radiator included.
All belts removed.
Alternator is already gone, but will include another with a Serp belt pully.
Carburator is gone.
Needs Valve job on Right (passenger) cylinder head, dropped #4's exhaust valve.
PostPosted: Tue May 09, 2006 6:06 pm    Post subject: Reply with quote
LMAO.. ended up sending the one Paul left me to the metal scrappers. Not much call for a worn out 2.8.
PostPosted: Tue May 09, 2006 6:28 pm    Post subject: Reply with quote
Correct me if I'm wrong, someone told me that the 2.8 has the same block as the 3.1 and 3.4. Also told me the 3.4 is almost a direct replacement for the 3.1 Confused
PostPosted: Tue May 09, 2006 6:41 pm    Post subject: Reply with quote
2.8 Arrow 3.4 or 3.1- Arrow 3.4 is a cake swap. tech article on TGO about it.
PostPosted: Tue May 09, 2006 8:36 pm    Post subject: Reply with quote
Wonder if you could make a gokart with that...
PostPosted: Tue May 09, 2006 8:39 pm    Post subject: Reply with quote
It's the same block style. Theyre all the same engine family. Chevy even sells a 3.4 crate as a replacement for early 2.8 s10 engines. They'll all interchange. However, they may not be the same block. Bore/cylinders could be different. Havent paid that much attention to the 60* sixes.
PostPosted: Tue May 09, 2006 10:21 pm    Post subject: Reply with quote
http://videos.streetfire.net/Comment/0/ed4a74cc-207b-4842-b85c-37177e8d3bd2.htm
Shrug
PostPosted: Tue May 09, 2006 10:29 pm    Post subject: Reply with quote
I don't think I'd have to worry about an N/A chev v6 being that fast. Laughing
PostPosted: Wed May 10, 2006 12:38 am    Post subject: Reply with quote
130HP on a go cart that small.... it woud rock your socks!
PostPosted: Wed May 10, 2006 4:53 am    Post subject: Reply with quote
I take that nobody is intrested in it.....
PostPosted: Wed May 10, 2006 5:33 am    Post subject: Reply with quote
Laughing odd that you mentioned it....I was gonna use the 4 speed and Toyota 2TC I have sitting in my garage for that.
"Welding is the solution to all your automotive problems, Chris. Its makes the impossible, possible."---Rob
