Fixed the front brakes today.
PostPosted: Sat May 06, 2006 6:05 pm    Post subject: Fixed the front brakes today. Reply with quote
Aside from the other things bothering me with the motor, I thought I should at least be able to stop and track straight while doing so. Car has been pulling to the left every time I stepped on the brakes. The right front rubber line was split around the "bracket" which attaches it to the chasis, and the left was not much better. These haven't been touched since I have owned the car and are probobly original to the car.
With new lines it stopps sooo much better Smile
PostPosted: Sat May 06, 2006 6:08 pm    Post subject: Reply with quote
Shocked i should get braided steel lines for my front brakes...
PostPosted: Sat May 06, 2006 6:58 pm    Post subject: Reply with quote
Did you go with Earl's or similer, or did you just swap then with OEM rubber lines?
PostPosted: Sat May 06, 2006 7:04 pm    Post subject: Reply with quote
Raybestos OEM rubber lines.
PostPosted: Sun May 07, 2006 1:23 am    Post subject: Reply with quote
I bet your 17's could tuck some c5 brakes very well. Smile
PostPosted: Sun May 07, 2006 7:24 am    Post subject: Reply with quote
We'll see after I get other things fixed first and then maybe start on suspension & chasis.
