Kage87Z Member
1969 Chevrolet Camaro
Posted: Thu Mar 02, 2006 3:43 pm Post subject: Bart strikes again! |
The problem was the inner tank fuel pump, and "Blue" has rejoined the living.
 _________________ "Are you guys ready? Let's roll."
Todd Beamer - 9/11
Never Forget
Posted: Thu Mar 02, 2006 3:44 pm Post subject: |
Man, you must be getting all of Barts luck.
My car is STILL not running. |
Posted: Thu Mar 02, 2006 3:54 pm Post subject: |
| Dewey316 wrote: | Man, you must be getting all of Barts luck.
Because I haven't been over to help.  |
Posted: Thu Mar 02, 2006 3:55 pm Post subject: |
Lol, if you are a pro at getting broken bolts out of the block... come on over tonight.  |
Sellmanb Member
Posted: Thu Mar 02, 2006 7:29 pm Post subject: |
| Dewey316 wrote: | Lol, if you are a pro at getting broken bolts out of the block... come on over tonight.  |
out of the block? ouch.
Have you got a torch ? I find that my MAPP gas torch helps me get bolts (amongst other things) out fairly easily once I get the right rythm down with it.
A trick I learned in autobody class... if you have a rusty, or just plain stuck bolt that's been sheered off and you want to make sure you dont bust an easy out on it, you take a torch, aim it at the bolt, once it gets glowing red (you'll know it) back off and let it cool for just a second, then put the torch back on it, and do that in cycles for a minute or two. Then try it and it should come right out.
I'm sure your bolt in the block is harder than anything I ever did in autobody class though  |
TecherB Princess B
Posted: Thu Mar 02, 2006 10:16 pm Post subject: |
the lamas problem is that the bolts have broken off inside of his block.
so they need to be drilled out.
so hopefully with paulys help and mine it will be up and running by noon saturday. |
Posted: Fri Mar 03, 2006 6:45 am Post subject: |
| TecherB wrote: | the lamas problem is that the bolts have broken off inside of his block.
I'm all about the square easy outs. That's how I got the headbolt out of my block! |
