fueling big small blocks
rice B-4
PostPosted: Fri Feb 10, 2006 3:54 pm    Post subject: fueling big small blocks Reply with quote
Can TPI (assuming that you run bigger injectors) fuel a 600 horse large displacement small block or dose it have pretty set limits?
"Horse power is how fast you hit the wall, Torque is how far you take the wall with you."
99 Camaro Z28 LS1
PostPosted: Fri Feb 10, 2006 3:58 pm    Post subject: Reply with quote
Fueling would be determined by injector size and pressure.
now TPI itself support 600hp worth of airflow, is a whole diffrent issue.
rice B-4
PostPosted: Fri Feb 10, 2006 5:25 pm    Post subject: Reply with quote
So 600 hp is the limit of air flow, can that be pushed?
99 Camaro Z28 LS1
PostPosted: Fri Feb 10, 2006 5:30 pm    Post subject: Reply with quote
I don't think TPI can even touch 600hp.
Only chance for 600hp with stock TPI, would be crap loads of boost.
Some advice justin, after our phone coversation. Start a thread, talking about the direction you are wanting to go, and your budget. Stat a dialog on diffrent combinations that will get you there.
rice B-4
PostPosted: Fri Feb 10, 2006 5:44 pm    Post subject: Reply with quote
Thats a good idea.
99 Camaro Z28 LS1
