90RSrocks Member
Posted: Thu Feb 12, 2004 11:02 pm Post subject: Electrical problem Version 2.0 |
I haven't had a chance to try swapping the malfunctioning right headlight with the left to see if it is the bulb yet, but I noticed a new problem today: the hatch pulldown motor is dead, so I am getting a nice cold breeze when I drive, and things are going to get wet if it rains.
I got an electrical circuit tester a while back, so I will check if the motor is getting current. If it is, where do you guys suggest I get a replacement motor for cheap (in the Portland area)? |
Midnight Sun Member
Posted: Mon Feb 16, 2004 4:07 am Post subject: |
kelly, i have had alot of problems with the pins in the relay on mine, clean them off with a screw driver it is an easy enough test to give it a shot  |
90RSrocks Member
Posted: Mon Feb 16, 2004 3:34 pm Post subject: |
| The pins on the top where it contacts the hatchlid? Those are already perfectly clean (on top at least, I'd have to take everything apart to see the rest). |
Posted: Tue Feb 17, 2004 4:06 am Post subject: |
| yes, you have to pull the back plastic panel, there is a relay mounted next to the pull down motor. check the connectors for that relay. |
90RSrocks Member
Posted: Tue Feb 17, 2004 3:45 pm Post subject: |
Cool, thanks. I will do so.  |
90RSrocks Member
Posted: Fri Feb 20, 2004 9:06 pm Post subject: |
Umm, never mind... After a few days, it started working fine again. Gotta love those GM electrical gremlins.  |
