Rebuilt Q-jet, now car pops
Sellmanb
PostPosted: Mon Jan 16, 2006 11:11 am    Post subject: Rebuilt Q-jet, now car pops Reply with quote
I did a minor rebuild to my q-jet. I took the 3 major pieces apart, cleaned all the carbon out of them, replaced a green plunger-like thing, and put new gaskets on. After I started it up, it idled at a nice RPM, and fairly steady, but I hear popping from the exhaust.
This is typical of a lean condition, correct? What did I mess up? lol.
Also, I made a set of plug wires with some MSD wires and boots, and I'm not completely sure if a couple of them are fully seated right now, but I doubt that would make the same sound, would it?
It does the popping a lot at idle and coming down from revving. It probably does it while revving as well, I just dont hear it as much.
PostPosted: Mon Jan 16, 2006 12:24 pm    Post subject: Reply with quote
naw, popping out the intake is a sign of a lean condition usually... because it gets hot and pre-ignites with the intake valve open.
PostPosted: Mon Jan 16, 2006 1:20 pm    Post subject: Reply with quote
But if the popping is out of the exaust, it could be exesivly rich, and the extra fuel is igniting in the exaust.
NHRA427
PostPosted: Mon Jan 16, 2006 4:13 pm    Post subject: Reply with quote
This may sound dumb but make sure 5 and 7 plug wires are right.
PostPosted: Mon Jan 16, 2006 10:10 pm    Post subject: Reply with quote
Bad powervalve?
Did you adjust the idle mixture with a vacuum gauge?
Sellmanb
PostPosted: Tue Jan 17, 2006 4:03 pm    Post subject: Reply with quote
It is more-so in the exhaust, I havent had problems with out the carb.
It actually only tends to do it right after I start it up. It does it once or twice (not bad, it just irritates me) and then smooth sailing from there.
I didnt adjust the idle mixture or anything. I did not move any adjustable parts, from what I know, they are all still set at the factory settings.
When I sniff the tailpipes they seem slightly rich at idle, but not excessively. I guess dyno will tell, eh ? Wink
I checked 5 and 7 and they were correct. I made sure they were all clipped on all the way and I guess one of them was slightly off and now it idles a little smoother atleast, but it still does the popping once or twice thing.
Should I even be worried about this? I'm just afraid that over time it's gunna blow up the cat.
PostPosted: Tue Jan 17, 2006 4:05 pm    Post subject: Reply with quote
Only if we find more people. Right now I don't know if we have enough. I'm going to call Steve tomorrow and talk to him.
