holley stealth ram help
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Tue Dec 27, 2005 8:44 pm    Post subject: holley stealth ram help Reply with quote
Well, we are looking at this intake
we have the long runner tpi right now.
will it work with the heads I have as far as the bolt angles????
summit says it will need aluminum heads, Iam sure I have seen this on a 305 with out aluminum heads. see below
whats the deal?
Make CHEVROLET
Engine Type V8
Liter 5.7
CID 350
Engine Size 5.7L/350
Beginning Year 1967
Ending Year 1995
Engine Family Chevy small block Gen I
Cylinder Head Style (application) Stock configuration
Application Notes Fits 1987-95 models with aftermarket aluminum cylinder heads.
thanks
scott
PostPosted: Tue Dec 27, 2005 9:51 pm    Post subject: Reply with quote
Yeah, I don't have aluminum heads. Laughing
I'm not sure why that says you need them but the main thing I thought was a problem was the center four bolt hole angles. It's drilled for the pre-87 and 87 and later angles
scott in wa.
PostPosted: Wed Dec 28, 2005 1:08 am    Post subject: center bolt valve covers? Reply with quote
You have the center bolt valve covers right?
What year is your engine, heads?
Did you have to drill this holes or oblong them?
Use tapered shims under the bolt heads?
Mine are the 87 ho 305 heads, should be the same as yours.
It looks like the center 4 bolts ate straight down in mine.
thanks
Scott
PostPosted: Wed Dec 28, 2005 1:24 am    Post subject: Reply with quote
Engine is stock '91 vintage with the centerbolt heads. All '87 and up use the centerbolt heads with the angled bolt holes
I've got these that I picked up at tacoma screw for $2 a piece (better than the$70 versions holley was selling)
The holes in my manifold come oblong'd and you can used either those bevelled washers or not and it'll seal either way.
scott in wa.
PostPosted: Wed Dec 28, 2005 1:42 am    Post subject: thanks Reply with quote
thanks dude.
Hey how much for the headliner
how much for the 3.5 pipe.
send me a pm.
thanks
scott
