What will break? 4K Neutral Drop
What's going to break?
Transmission, duh you built it
22%
 22%  [ 2 ]
Axles, what a weak part of the 10 bolt
0%
 0%  [ 0 ]
Driveline, that aluminum can will be just that
11%
 11%  [ 1 ]
U Joints, it happened to my 4x4?!
11%
 11%  [ 1 ]
Converter, factory converter means bang
0%
 0%  [ 0 ]
Rear Diff, it's just not a good idea even with your stud girdle
22%
 22%  [ 2 ]
Something else?
11%
 11%  [ 1 ]
Don't do it you idiot! AAA Doesn't cover race tracks!
22%
 22%  [ 2 ]
Total Votes : 9
PostPosted: Tue Oct 18, 2005 10:53 am    Post subject: What will break? 4K Neutral Drop Reply with quote
Brandon was so kind as to give me a doner transmission to fix mine, and a stock converter. Brandon ALSO thinks that I should do a 4k Clutch Dump at the track since it isn't a stall, so he can see the carniage!
PostPosted: Tue Oct 18, 2005 4:24 pm    Post subject: Reply with quote
I voted rear end. Are you going to try this soon?
PostPosted: Tue Oct 18, 2005 4:26 pm    Post subject: Reply with quote
We need more specs to descide what will break?
what tranny did he load you? 700r4?
(Deep down inside, i'm going to go with the Pinion gear, if anything breaks)
PostPosted: Tue Oct 18, 2005 7:57 pm    Post subject: Reply with quote
Do you still have an Auburn posi unit in there? Laughing
A little birdie told me they don't like shock loads. Embarassed
Of course another little birdie told me that it was prolly too much preload on the pinion bearings. Laughing so hard it hurts
PostPosted: Tue Oct 18, 2005 8:37 pm    Post subject: Reply with quote
TH350 with lots of unworn parts and stellar clutches.
Eaton Posi, Richmond Gears, Stud Girdle.
PostPosted: Tue Oct 18, 2005 9:31 pm    Post subject: Reply with quote
If anything gives it will be in the driveline department. Cool
PostPosted: Wed Oct 19, 2005 11:15 am    Post subject: Reply with quote
I am banking on the trans or converter, should I get that stupid and try it lol
PostPosted: Wed Oct 19, 2005 11:16 am    Post subject: Reply with quote
What little birdy was that? I've got a solid crush sleeve too.
PostPosted: Wed Oct 19, 2005 4:59 pm    Post subject: Reply with quote
Just what color was this birdie?? Very Happy
Thats a 454 convertor.. I really don't think it will be the part to break. Out of all those parts I think you'll corkscrew the driveline.
