injectors on e-bay, what do you think?
scott in wa.
1988 Chevrolet Camaro IROC-Z
PostPosted: Tue Oct 18, 2005 12:19 pm    Post subject: injectors on e-bay, what do you think? Reply with quote
8007398200
thats the number on e-bay .
Iam thinking of buying them.
what do you all think????
shoot Iam trying to run with the old 19# in the 350.
thanks
scott
PostPosted: Tue Oct 18, 2005 4:43 pm    Post subject: Reply with quote
Never heard of them Scott but the seller has excellent feedback and I read several of the comments that the injectors work fine.
For comparison, Ford racing 24lb injectors on Summit go for $220. The shipping will be comparable. These are new but will not be flow matched. Those same Ford injectors on Summit that I referenced above flow matched are like $360 Shocked
You will definately want to modify your injector constant in your chip with those. IIRC those will flow like 26lb injectors at our pressures.
