| What's going to break? |
| Transmission, duh you built it |
22% |
[ 2 ] |
| Axles, what a weak part of the 10 bolt |
0% |
[ 0 ] |
| Driveline, that aluminum can will be just that |
11% |
[ 1 ] |
| U Joints, it happened to my 4x4?! |
11% |
[ 1 ] |
| Converter, factory converter means bang |
0% |
[ 0 ] |
| Rear Diff, it's just not a good idea even with your stud girdle |
22% |
[ 2 ] |
| Something else? |
11% |
[ 1 ] |
| Don't do it you idiot! AAA Doesn't cover race tracks! |
22% |
[ 2 ] |
| Total Votes : 9 |
Posted: Tue Oct 18, 2005 10:53 am Post subject: What will break? 4K Neutral Drop |
| Brandon was so kind as to give me a doner transmission to fix mine, and a stock converter. Brandon ALSO thinks that I should do a 4k Clutch Dump at the track since it isn't a stall, so he can see the carniage! |
Posted: Tue Oct 18, 2005 4:24 pm Post subject: |
I voted rear end. Are you going to try this soon?
Posted: Tue Oct 18, 2005 4:26 pm Post subject: |
We need more specs to descide what will break?
what tranny did he load you? 700r4?
(Deep down inside, i'm going to go with the Pinion gear, if anything breaks) |
Posted: Tue Oct 18, 2005 7:57 pm Post subject: |
Do you still have an Auburn posi unit in there?
A little birdie told me they don't like shock loads.
Of course another little birdie told me that it was prolly too much preload on the pinion bearings.  |
Posted: Tue Oct 18, 2005 8:37 pm Post subject: |
TH350 with lots of unworn parts and stellar clutches.
Eaton Posi, Richmond Gears, Stud Girdle. |
Posted: Tue Oct 18, 2005 9:31 pm Post subject: |
If anything gives it will be in the driveline department.  |
Posted: Wed Oct 19, 2005 11:15 am Post subject: |
| I am banking on the trans or converter, should I get that stupid and try it lol |
Posted: Wed Oct 19, 2005 11:16 am Post subject: |
| rjmcgee wrote: |
What little birdy was that? I've got a solid crush sleeve too. |
Posted: Wed Oct 19, 2005 4:59 pm Post subject: |
Just what color was this birdie??
Thats a 454 convertor.. I really don't think it will be the part to break. Out of all those parts I think you'll corkscrew the driveline. |
