		| Author | Message |
		| Fc_Soldier Member
				|  Posted: Sat Sep 24, 2005 5:19 am    Post subject: Took it finally to the track!! :P |   |
				| temp 76 humidity 86
 barom 29.36
 I weigh in about 3560
 r/t    .709   first time
 60   2.01
 1/8  9.257  75mph
 1/4  14.3    96mph
 I need suspension work I was churpin off the line. And I had old bad tires, I think if I upped the stall converter 2400 or 2800, lower control arms, lost some of the weight,and tires Ill be in 13.9 for sure.
 In all Im happy how it performed suprised me and everyone else. First time at the track for this one. I had a honda civic next to me he ran a 17.7. I came off line great besides the hook up issue, it just didnt bite hard and I did smoke them alittle in the staging .
 Racing wothout t-tops good or bad? Less wiehgt but with down force will it drag me down. Windows up and all.
		| Back to top |  |
 1989  Pontiac  GTA
				|  Posted: Sat Sep 24, 2005 10:56 am    Post subject: |   |
				| Man that is pretty good. Was that with street tires?
		| Back to top |  |
		| Dewey316 The Lama
 1990  Chevrolet  Camaro RS
				|  Posted: Sat Sep 24, 2005 10:58 am    Post subject: |   |
				| That is what happens when the track is actualy prepped.
 John --  13.4 @ 106
 Mike --  14.2 @ 116
 Paul --  13.1 @ 108
 Do you see a trend Mike.
		| Back to top |  |
		| Fc_Soldier Member
				|  Posted: Sat Sep 24, 2005 11:01 am    Post subject: |   |
				| Yeah it was street goodyears 245/50/16 with 3:73 gears. It just didnt grab hard and it felt loose. |  |
		| Back to top |  |
 1989  Pontiac  GTA
				|  Posted: Sat Sep 24, 2005 11:50 am    Post subject: |   |
				| Oh and I would think that running with t-tops off would cost you on the upper end. Don't have any data to back that up, just seems that at some pint it would create a lot of drag. That hatch seems like a parachute  .
		| Back to top |  |
		| ET phone hoME Member
				|  Posted: Sun Sep 25, 2005 7:36 am    Post subject: |   |
				| jeez i'd be careful about racing with the tops off. my headliner has been beat to hell and im afraid to drive over 45 mph with my tops off right now. too expensive to repace ATM. _________________
 1990 Camaro RS, Black w/ Red Int, V6 3.1L, Auto, T-Tops.
		| Back to top |  |
		| Dewey316 The Lama
				|  Posted: Sun Sep 25, 2005 8:06 am    Post subject: |   |
				| I'm supprised the let you run.  I know when tried to do that, they told us if we did, then the car would have to meet the convertable rules, which means we would have needed roll bars. |  |
		| Back to top |  |
		| Fc_Soldier Member
				|  Posted: Sun Sep 25, 2005 10:16 am    Post subject: |   |
				| No I was asking if you could. I ran with my tops on. But when I showed up at the gate with them off they said nothing.
 I ran a 93 octane that night, should I run a 108 oct next time?
		| Back to top |  |
		| chevymad Master B
 1987  Pontiac  Formula
				|  Posted: Sun Sep 25, 2005 2:36 pm    Post subject: |   |
				| If you use higher octane then the motor needs you'll actually slow down. The higher the octane the slower gas burns. Only advantage to high octane is being able to run more compression which makes up for the slow burning fuel.  If you have no knocks/pinging now you're fine on what you're using. |  |
		| Back to top |  |
		| Dewey316 The Lama
				|  Posted: Sun Sep 25, 2005 3:13 pm    Post subject: |   |
				| I run on 87, unless I'm on the spray, then I usualy toss 92 in. |  |
		| Back to top |  |
		| Fc_Soldier Member
				|  Posted: Sun Sep 25, 2005 6:01 pm    Post subject: |   |
				| I was knocking with the 87 oct but the 93 seemed fine I guess Ill go with that! |  |
		| Back to top |  |
				|  Posted: Mon Sep 26, 2005 10:05 am    Post subject: |   |
				| haha when i first bought my car (v6 3.1) i would get 12 mpg on 87 and 18 mpg on 92. weird huh? got it fixed now where i get about 18 on anything.
 for speed....
 octane - acceleration
 87 = SLOW
 89 = SLOW
 92 = SLOW
		| Back to top |  |
